Question about Bang and Olufsen Beocenter 9300 Shelf System
Beosystem 5000 CD player jammed. Also receiver/preamp shuts itself off occassionally Does anyone fix these? Love the system
Why does connecting Sony PSLX2 deck to AUX input on an HD51 Technics amp yield hardly any sound?
There could be an output-input mismatch. As an experiment, try connecting your deck to some other audio input on your Technics amp.
Jan 11, 2016 | Sony Audio Players & Recorders
Beosystem
first what is the error
if its no disk first clean optical lens dust in upper layer,
then check motor its carbon brush motor replace it,
then check strip cable remove then clean the track then plug in.
Apr 28, 2014 | Bang and Olufsen Beosound 2000 Shelf...
Low hum on one radio preset on Beosystem 2500
local interference find another frequency for classic fm there are lots
Jul 21, 2013 | Bang and Olufsen Audio Players & Recorders
Bang olufsen beosystem 2500
This can be a problem with the radio stations itself, if its doing with all the radio stations then it must be a setting on you radio.
Jul 07, 2013 | Audio Players & Recorders
My cd player on my 2003 neon has a 6 cd set up and it will load the cds fine but reads the tracks,in no certain order,,can it be fixed?
check for a random button in the control panel as it appears that the unit is selecting tracks at random. See if you can turn random off.
Feb 21, 2013 | Cars & Trucks
The sound is really low if i press the aux tape cd phono or vcr the sound is there but really low
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
2 Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4. Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5. Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
May 27, 2012 | Audio Players & Recorders
I have a Harman Kardon HD750 CD-player for about 5 years. Since a few months, I have a definite 'hum' on the right channel. Even when disconnected from all other equipment and just listening by...
Hello
As hum is heard through its left channel winle playing CD only denotes that it origin is from the preamp: side of the circuit itself. If power ampifier has the trouble, the hum will be heard even when the CD player is not playing. When CD player switches on, the preamp: section gets the working voltage, and starts working, while it will be in dead condition when CD stops. So you shoud check all the smoothing capacitors of that side; I advice you to change all of them, since it is difficult to detect the faulty, if you haven't a multimeter which can mesaure capacitance. This must solve your problem. OK.
Jan 09, 2011 | Harman Kardon HD750 CD Player
Wont Take Cd's
Assuming you've looked inside to see if anything is jammed in it, you'd probably have to take the case off to see if the drive links are broken.
Sep 02, 2008 | Alpine CDA-9855 CD Player
Only bass coming through speakers
Nevermind, the unit fixed itself... i dont know what happend...
Mar 07, 2008 | JVC Arsenal KD-AR3000 CD Player
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
