Question about Samsung SP-67L6HX 67 in. HDTV-Ready DLP TV
SP67L6HX Samsung, image cuts out and tv reboots, tv is 6 years old
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Red dots going across screen when watching TV is this worth fixing and how much would it cost? approx. 5-6 years old.
This tv is a DLP one - the image is created in a special chip with tiny mirrors on it; each mirror is commanded individually by an image processor that in your tv is starting to fail.
The replacement of the mainboard on which this processor is soldered would cost you about $300 - i don;t think the tv is worth as much. Keep using it for as long as you can and use this time to save for a new one.
Jun 03, 2011 | Samsung HL-S4266W 42" HDTV
We have a 6 year old tv. We are starting to see
hello,
If your problem like pict below :
(worst dot's on screen)
Change the DMD.
Good luck.
Mar 23, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
5-year old 32 in. Samsung which only displays a fuzzy gray image
It sounds like the T-CON board problem, you can try reseating the connector first, the board is mounted under the metal shield which sometime can be difficult to get to.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 07, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Dec 31, 2009 | Toshiba Toahiba Satellite A70 A75 M35...
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
Jun 15, 2009 | Samsung PN50A450 50 in. Plasma HDTV
Samsung SP-67L6HX 67 in. HDTV-Ready DLP TV Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
