Question about Marvel 6BAR-BD Beverage Cooler
The cooling panel has a leak, can I replace it myself?
Need to figure out if water leaking out of the bottom passenger part of car is waster pump and how to replace it myself (money issues).
See if your local parts store can rent you a cooling system pressure tester and use it to pressurize your vehicles cooling system. It sounds like you may have a leaking heater core, so look beneath the dash when it is pressurized. (It should be obvious w/ 12-15psi of pressure in the system.
Oct 30, 2013 | Cars & Trucks
When there is a fault with the back to base security system it knocks out the heating/cooling control panel, even though now I have 2 control panels - 1 for heating 1 for cooling.How can the system be
this has appeared under truck and cars try the correct heading to post this question in please and perhaps someone will see it then and not a old washed mechanic like myself
Dec 30, 2011 | Cars & Trucks
How to fix my 2003 Mitsubishi Montero is overheating problem?
May want to have a shop do a pressure test on your cooling system. I had a vexing overheating problem that two shops misdiagnosed and "repaired" $$. Turned out the radiator had a leak that only occurred under pressure, and finally was revealed when the leak became obvious, and then did the replacement myself. Good luck.
Dec 27, 2010 | 2003 Mitsubishi Montero
I was told my 2006 camry water pump leaked. Is there any way to visually verify the pump leaks? I want to confirm myself before spending $400 for the replacement.
you could pressure check cooling system and look for your leak not certain if 06 cam engine is equipped with timing belt driven waterpump but if it is and it is leaking under pressure you should see it coming out of timing cover
Sep 16, 2010 | 2006 Toyota Camry
The front air conditioner on my 2003 dodge grand caravan has a small leak that the dealship says is under the dash. Can I just put a charge on the front unit the back unit blows cold air. Is this...
There is only one system, so your conclusion doesn't make sense. If the front evaporator is leaking, the whole system will lose charge, and the back will not be cooling. Your problem may actually be the front blend door. Recommend you get a second opinon. Evaporator replacement is much more than $300.
Jan 23, 2018 | 2000 Dodge Caravan
1997 Buick Century Overheating
Have someone pressure test the cooling system - you likely have a head gasket leak
Apr 10, 2010 | 1997 Buick Century
Can I replace the front door panel kit myself?
No, it needs a special aligning for avoiding the microwaves leaking outside the oven.
If you replace it anyways, check with a microwave detector that there isn't any leak.
Oct 27, 2009 | Sharp R-1501 Microwave Oven
Replacing a heater core myself
It a depends how far you are into it. But this may help
you dont have to remove the steering wheel and column trim, you can just un bolt the column (four bolts) and lower it so it rests on the seat. Some vehicles you dont have to remove the freon / hole a/c module if equipped.
You can pull the instrument panel/carrier far enough away from the core support to slip the heater core out the top of hvac box. Be sure to properly flush your cooling system and replace with dex-cool otherwise you might be dueing the repair again. good luck hope that helps you out
Nov 29, 2008 | 1999 Chevrolet Silverado 1500
Marvel 6BAR-BD Beverage Cooler Logo
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
