Question about Kenmore Vacuums
I have a Kenmore Dehumidifier 70 Pint Low Temp. It is 2 years old. It works but is VERY noisy and vibrates about an hour into the cycle on a 3 hour on/off cycle and about 2 hours into the cycle on a 6 hour on/off cycle.. It sounds like it can't change to the next cycle. I took it to Sears repair and they said it was fine, just noisy. It never used to be noisy like that.
  • raehepburn Nov 15, 2010
    Thanks for your answer. I'm sure you're right about what is going on, but what do you mean by a shrouding and also is liquid silicone WD40. On the dehumidifier I have there is the removable bucket at the bottom, then above that there is an outside grille which you can remove. Behind that grille is the filter (which you can remove to clean) and then a set of coils which you can clean with a toothbrush and warm water. The motor is behind the set of coils and there is no way you can get to it or any moving parts as they are all behind the coils. I wouldn't know how to remove the coils as there doesn't seem to be a way. That being the case, where exactly would I squirt the liquid silicone.
    Thanks so much.
  • raehepburn Nov 16, 2010
    The solution was very helpful. Thanks.
  • Kenmore Master
  • 43,501 Answers
The noise is a harmonic vibration that the compressor creates....as things wear and get loose, like the shrouding around the unit the vibration causes it to rattle and make a very loud noise.... the compressor at that point is working the hardest and makes the noise even worse,,,,
As you were told, there really is not much you can do other then finding out were the movement is and trying to restrict that movement....I have done that with things like clear silicone...by squirting it into and around the joints that are moving to create the noise the monement is limited and it helps to quiet the unit down...
Not sure what elese to tell you.... it's like it really isn't broken, but it sure is annoying!! Hopefully tou can get my little trick to work...
heatman101
Posted on Nov 15, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Nov 15, 2010
    What I mean about the shroud.... is the cover or enclosure that houses the internal parts...
    as far as the silicone goes... most any clear silicone caulking will do....
    figure out where the rattle is coming from and then place the silicone there to "glue" the parts together and stop the noise....
    If the noise is an internal compressor noise then there is nothing you can do about it... but I don't think that is your problem...
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 | Vacuums
I have hooked up a hose to my firgidaire energy star dehumidifier, 25 pint, but it is still draining into the bucket. What do I do?
Cut out the plastic in the bucket where the hose attaches to allow the water through.
Jun 01, 2011 | Vacuums
Our dehumidier is running but there is not water in the tray???
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room may be relatively low and you probably have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work.Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 29, 2011 | Vacuums
It turns on and shuts off just like it is supposed to but the thing is bone dry. The humidity is at 56% so it should be able to dehumidify. It is just a little over 1 year old, help me please?!!
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means it is actually working well. The humidity level in the room is probably just relatively low and you probably have the unit turned up too high for the conditions.
Joe.
May 24, 2011 | Kenmore Vacuums
Have dehumidifier 1yr old what is standard warranty on this product
Standard warranty is determined by the manufacturer and you have not stated what model or make of dehumidifier you have.
Most appliances are covered by 1 year, some by more. If you purchase refurbished, remanufactured or reconditioned units, you could get a 30day, 3 month etc. and this differs between retailers.
Your warranty is honoured by the retailer and not the manufacturer so you could contact them to see.
Feb 06, 2011 | Vacuums
Power brush not working well
You probably have a worn belt that drives the beater bar... 2 year old belts with reasonable use are more than likely due for a replacement. You should be able to get a replacement drive belt from Sears and change it yourself.. The baseplate of your power brush seperates and should provide access to the beater brush and drive pulley system.. Hope that helps..
Aug 25, 2008 | Kenmore 22812 Bagged Canister Vacuum
BEATER BAR
The newer models have plastic end caps that will melt when the bearing heats up. This will cause the cap to go "off-centre" and the roller will vibrate badly. If this is the case, you will have to replace the roller.
If the belt is a geared drive, check the belt for any missing teeth.
Jan 30, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vacuums Logo
149 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
