Question about Kenmore Dryers
The flame will not come on. Kenmore dryer Model/stock # 97478100 74781. Serial # MC4408298. Can you help me to fix this problem? Thank's, Louis
futureloginn
  • 734 Answers
SOURCE: dryer won't heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
  • 113 Answers
SOURCE: Inglis Gas Dryer Does not heat up at all, No spark, no flame
When you start the dryer , after a few seconds do you hear a distinct click sound from inside the bottom of the dryer at the burner assembly? If you do not, you most likely have a bad thermal fuse, part# 3392519 or 3390719, depending on your dryer. Its the same fuse just different shape, both will work. This is most likely your problem. If you do hear a click, you may have a bad ignitor. Best way to test is to check for 120 at the ignitor. If you have anymore questions or need parts feel free to ask in my forum at www.washermd.com, thanks, Dave
Posted on Dec 16, 2008
SOURCE: my kenmore 70 series dryer quick working
My wife was cleaning the top part of the dryer, and took off the knobs to clean them and the dryer will not start up and not run at all. where do I start to problem solving?
Posted on Dec 19, 2008
  • 3 Answers
SOURCE: my kenmore dryer turns on
check your sensor
Posted on Jan 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore 90 series dryer's pilot light is out.
If your flame sensor is open then the ignitor will not fire up. Read more
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 07, 2009
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Need help with gas dryer Kenmore 90 series serial #MK0211114 the gas does not ignite electric is working fine
This could be several things thermal fuse,hi limit thermostat,flame sensor, ignitor,or coils. There is a video on troubleshooting a gas dryer at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting procedure. It is a different model but troubleshooting will be the same. You could also check the video on the electric heating element replacement that is a kenmore 90 and most of the parts will be the same. That one will give you a good idea of what thermostat is what.
Mar 24, 2010 | Kenmore 73952 Gas Dryer
Dryer will not start when button pressed. Several times yesterday it did start but stopped few minutes later.Kenmore brand. Model 11062812101. Serial MM1310180. Thank you
is it a gas or electric model, if gas the ignitor,flame sensor,control board,if its electric,element,hi-limit,thermistor switch, control board, lack of correct input voltage,bad motor start capacitor on either model
Nov 01, 2009 | Dryers
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
My Kenmore 90 series dryer's pilot light is out. What can I do? I have a Kenmore 90 Series Model 76912692, Stock 76912, Serial No. MG2701491. Is it straight forward to change the igniter? How much does it...
Mar 07, 2009 | Kenmore 84052 Dryer
My kenmore 70 series dryer quick working
Aug 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
https://www.repairclinic.com/Shop-For-Parts/a8b6d600503/Model-11072212100-Kenmore-Dryer-Parts
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Dryers Logo
142 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
