Question about Motorola Walkie Talkie 2-Way Radio
Are motorola and midland radios compatable My hunting group has midland radios and they operate on channel 5pt5 to get away from other groups in the area I have motorola and when i go to 5pt5 my radio receives but will not talk When we are not on the odd channel they work fine Cant find my instructions Please help
Agent Ken
  • 250 Answers
SOURCE: How do I get my motorola T5725 radios to talk to eack other
Hell ssalah,
Most of the time when one radio cannot talk to the other radio it means that the Privacy Codes are not configured properly. In order for the two radios to talk to one another they both have to be set to the same channel and Privacy Code or the Privacy Code function needs to be turned off on both radios.
The Privacy Codes can be used to keep the radios silent unless they receive a signal from another radio using the same code. This enables the radios to be used on busy channels with a minimum of interference. If Privacy Codes are turned off on one radio and turned on for the other radio, the situation you describe will occur.
Consult the user's manual for information on the Privacy Code function and either disable the function on both radios or set both radios to the same code.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 17, 2008
Benimur
  • 6966 Answers
SOURCE: t5950 2-way
Initially, pls check that the displays of both radios are identical. This is important to establish that the channel/frequency, Interference eliminator settings and all others are the same that both are paired. In some instances, the radio settings may not be changed if it is locked. Top unlock, press on the MENU button for about 3 seconds. For all other settings, pls refer to the user's manual.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
eradiostore
  • 1654 Answers
SOURCE: I HAVE 2 MOTOROLA RADIO' S MODEL# EX500 THAT ONLY TALK TO EACHOTH
Assuming you have checked all the channels for functionality, it appears your radios need reprogrammed. This is something which would require you taking the radios to your local Motorola dealer.
Posted on Jan 24, 2009
eradiostore
  • 1654 Answers
SOURCE: how to set interference eliminator code on motorola two way radio
The FV300 does not have the interference eliminator code feature. (Sorry)
Posted on Jun 30, 2009
eradiostore
  • 1654 Answers
SOURCE: the radios are on the same exact channel but will
Recheck your Frequency, Interference Code Eliminator and the Qt Filter. If all 3 are set identical. If this doesn't clear up the issue. Next set your Qt Filters and your Code to zero (off). Lastly, on the radio which has problems transmitting, check your battery. A bad battery will cause intermittent transmit issues. Trade the battery with a known good battery and see if the problem clears up. Clean your battery contacts with a pencil eraser.
Posted on Nov 08, 2009
Midland lxt320 making static noise
Hi David,
Not being familiar with the Midland brand, I personally can't give advice for for your query, but there is a solution!!!
Please join (FREE) yahoo group SPECIFIC to your radio Make/Model, I believe a group has started for this make of radio, so they are the people with the expertise and info to assist you, you can find free downloads for manuals, diagrams and software as well for your radio.
I do hope this leads to a resolution to the problem.
Warm Regards,
Peter
Feb 24, 2013 | Midland LXT320 (14 Channels) 2-Way Radio
Looking for schematics of midland 75-822 rev 2; does anyone know why this radio is named 75-825?
The brand name or make of the radio is Midland and the Model Number is 75-825.
it belongs to the 75-820 series of radios, therefore anything under the hood is compatible.
Now to the answer to your query.
join yahoo group SPECIFIC to your radio Make/Model, the techies there will help you with any questions you have about the unit and yes you can download manuals, schematics and other goodies for your radio.
It's free to join and download, I know, I'm a member of another radio group.
Best regards,
Peter
Dec 16, 2012 | Radio Communications
Do not see all phones available to add to a hunt group
This is a Internet Explorer issue. If you use it in "compatibility view" it will show all users when you click on show all users. Otherwise use google chrome or firefox.
Feb 21, 2012 | 3Com NBX Computers & Internet
Need hep programming a new uniden bcd396xt scanner
Unfortunately, you didn't specify if you needed assistance with programming digital or conventional radio systems.. but here is the info for conventional systems. Since a conventional system is really a collection of frequencies, the first thing you need to know is the frequency for each channel you want to program.
  1. Go to the Program System menu and choose New System .
  2. The scanner will prompt you for the System Type. Select Conventional .
  3. When the scanner prompts you confirm, tap YES .
  4. The scanner creates the system with a default name. Select Edit Name if you want to change it.
  5. If you need to change any of the system properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel group Each conventional system can contain up to 20 channel groups, and all systems must contain at least 1 channel group.
  1. On the Program System menu, select the system you just created.
  2. Go to the Edit Group menu and select New Group .
  3. If you need to change any of the channel group properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Create at least 1 channel in each group Each conventional system can contain up to 1000 channels in each group, and all groups must contain at least 1 channel.
  1. On the Edit Group menu, select the channel group you just created.
  2. Go to the Edit Channel menu and select New Channel .
  3. Input the frequency for this channel in MHz.
  4. If you need to change any of the channel properties, you can do that now. Unless a property is Required , you can operate the system without changing the default settings.
Mar 04, 2011 | Uniden BCD396T Handheld Scanner
We purchased the midland two way radio, the problem is the channel we are on we only can hear every one in our group, but can not communicate if they are on their radio. How can we get on the same...
You should ask the others what channals they are on if you cant for whatever reason then scan for a frequincy that has others on it by hitting the scan butten and hitting the channal up or channal down butten, if you can tthen talk on each channal in order and wait 10 seconds for a reply then go to another channal and try agean, im not sure if you can hear others unless they have the same brand radio's but i could be wrong, i am also not sure if the scan butten will work so after it goes through all of the channals 2 times then try the other suggestion. you also want to make sure you have good batteries in when you try.
Hope this helps
Gamer71796
Feb 14, 2011 | Midland Two Way Radio
My motorola has an emergency alert button on top, when pressed and held it sounds an alarm on all other radios near it. we pushed it to test and it works well and is a cool feature. however, the call tone...
Your radio may be functioning normally for the emergency alert. Here is an excerpt from the user guide:
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Oct 22, 2010 | Motorola MR355R Two Way Radio
Need instructions to reset my Midland weather alert radio. Time and channel for Amarilli, TX.
On the Midland Weather Radio WR-100 web page of this website, scroll down until you get to the "Manual" heading. There is a link there (WR-100 Weather/RDS Radio Manual); click it and your instructions manual will come up in a .pdf format. To get the frequency channel for Amarillo, go to this website- http://www.nws.noaa.gov/nwr/CntyCov/nwrTX.htm. I do not know what county you live, so you will have to look at every county listing that has your city name in its group. When you find the information you need, insert it into your radio.
Jun 07, 2010 | Midland WR-100 Weather/RDS Radio
Is the midland gxt 650 compatable with the g12
All type-accepted GMRS radios operate on the same frequencies and use the same type of transmissions. Channel numbers are the same on most models, but check the channel/frequency chart in the radio's operating manual to be sure.
Bill B
May 30, 2010 | Midland Two Way Radio
HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator: What is the toggle switch on the top of the Microp...
The toggle switch on the portable radio can be programed for different options like changing zones ( groups ) of radio channels.
It depends on how it is programed. A lot of times it is turned off in the program.
May 18, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Change scanning feature for different channels
When having the radio programmed indicate to the programmer which channels you would like to have in a specific scan group. They an at that time set up a particular group for you.
Mar 13, 2008 | Motorola Radio Communications
Radio Communications Logo
158 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
