Question about Canon Rebel XT / EOS 350D Digital Camera
Err CF Did not use camera for a while - it was working perfectly previously Charged battery etc - went to use and got this message Err CF What can I do
  • jackmeboy Jun 26, 2008
    Have had repairs made twice in five months to the bent pins at bottom of CF chamber. Canon had repaired at no cost but insists that it is not a warranty item. There is only one way to insert the "chip" so the consumer is not "forcing" it into the slot, however the pins still get bent. I believe it is a quality defect and Canon should fix the cameras to prevent the accidental bending of the pins. It is a great inconvenience and disappointment when on a trip to find out the camera will not function.
    jack
I have same problem, i cant load the card. the pins are good but the card doesnt go all the way down. please help
Posted on Jul 10, 2008
The only possible for this error is. where the cf plugs into. the pins at the bottom of the CF chamber are bent. A close inspection with a good light should confirm this
Posted on Jun 22, 2008
My canon eos rebel xti keeps showing error code 99
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
following:
steps:
camera body.
May 25, 2009 | Canon Cameras
ERR 99
try cleaning the battery contacts and the contact spring tabs in the battery compartment... also visually check to make sure the tabs are sticking out to make good contact with the battery terminals.
Also here's an excerpt from a canon blog ..it's a quote from a Canon usa service guy...
hope it's a help for you..
One of our participants in the long comment thread below (Tom) got this in a message from Canon USA. It may help some of you isolate the problem before you post a comment/question.
To isolate the cause of the issue, we suggest that you do the following:
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
May 25, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Err 99 when I attach lens
I had the same problem with my camera and i found this guide online very helpful in most cases
camera body.
Jan 29, 2009 | Canon EOS-10D Digital Camera
Err 99 & err cF in my canon 350d camera
had the same problem before
camera body.
Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hi Ben ,
camera body.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Canon Rebel XT / EOS 350D Digital Camera Logo
215 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
