Question about Pentair Pool & Spa
I have a an Electronic Chlorine Generator for my pool and and seem to be scooping out about 1/4 to 1/3 cup of calcium everyday from the bottom of the pool. Is this a common problem? I don't think I had the problem the first few years of use and after experiencing it for a year with the original device, decided to install a new generator but I still have the problem. Any suggestions
  • 310 Answers
These generators need to be cleaned every 3-6 months at least. cleaning the cells in a light 1 to 4 acid solution will usually do it.
If your Calcium hardness is too high to begin with , you will need to clean this much more often.
If your calcium hardness levels are above 250-300 parts per million, you just need to treat for calcium. There are plenty of conditioners out there that will do this for you.
Posted on Nov 15, 2010
How much of a cup is 20 grams of granule chlorine
check the links, but best by far is an electronic kitchen scale as grams is a measure of mass (weight) and a cup is a measure of volume.
chlorine dosage calculations and measurements pool volume
www.swimmingpool.com.au/ChemicalBalanceChart.html
  1. Cached
  2. Similar
40 x 20 x 5, 12.0 x 6.0 x 1.5, 110,000 ... CHLORINE DOSAGE CHART (This chart is a guide only)DOSE PER 10,000 LITRES ... Granular Chlorine, 80 Grams ... Tables I-1 and I-2 provide volumes in drops (dp), milliliters (mL), teaspoons (tsp), ... The values moving down a single column represent how many of the units at the ...
Chlorine to prevent swimming pool water problems - POOL WIZARD
www.havuz.org/pool_pool/pool_maintenance/water_testing/chlorine.htm
  1. Cached
  2. Similar
When planning to buy a test kit to measure the chlorine levels in your pool, it is ... Take the water sample from at least 20-30 cm below the surface and at least ... As a rough guide, a pool needs about 600 grams of granular chlorine (2-3 cups) ...
How many grams of granular chlorine does a cup hold - Answers.com
www.answers.com > ... > Categories > Science > Units of Measure > Metric System
  1. Cached
  2. Similar
280 +/- 5% ... many grams in a tablespoon chlorine? Approx 20 grams ... How many cups of granular pool chlorine in one pound? 2 cups. 48 people found this ...
How to measure chemicals??? - Trouble Free Pool
www.troublefreepool.com > Forum > Swimming Pool Care > Just Getting Started
  1. Cached
  2. Similar
May 26, 2013 - 7 posts - ‎3 authors I've been using a measuring cup but I assume when hth says 8 oz....they mean 1/2 pound. ... Ha, found the answer on this video, guess they do mean fluid ounces. ... Using CYA granules for example - if my measuring cup said 32oz, that is 2 lbs, correct? ... 8638 gallon 20'x52" Intex ultra frame round AG.
How to measure Chlorine Granules? - What's The Best Hot Tub
www.whatsthebest-hottub.com > Hot Tub Forum > General > Hot Tub Forum
  1. Cached
  2. Similar
Aug 9, 2006 - 15 posts - ‎8 authors My question is, since I only have a 100 gallon spa, and the Chlorine Granules say to add 1/2 oz per 500 gallons of water, how do I know and ...
how to convert 10 grams into understandable unit? ' Yahoo Answers
https://ca.answers.yahoo.com/question/index?qid=20100527135338AAbL0Np
  1. Cached
  2. Similar
May 27, 2010 - I have to put 10 grams of powdered chlorine in my kids swimming pool ... But you can't use a measuring cup or tablespoon to measure mass ...
Nov 15, 2016 | Computers & Internet
What is wrong with my Aqua Rite Electronic chlorine Generator.
when unit goes off see if voltage from transformer if not bad transformer if os bad cell and sensor
Sep 09, 2016 | Hayward-Goldline Aqua-Rite Electronic...
Cannot remove electrode cell duo clear
probably calcium deposits pour muriatic acid 4 parts water to 1 part acid in a bucket then try to pour into to release cell
Apr 19, 2014 | Zodiac Duo Clear System Chlorine...
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
Hayward Electronic chlorine generator bond to Jacuzzi magnum 1000
when i done mine i cut the pipe and glued another connector in to the pipe that goes to the jets ,
Apr 10, 2012 | Pool & Spa
We have an Intex above ground pool that takes salt and converts to chlorine. We filled it about a month ago and all was fine for a few weeks, then in the past week the water began turning green. We have...
Intex chlorine generators are very low output generators that fail very often. There is a reason they are so cheap. They do not work well. When using a chlorine generator, it is important to test manually for salts and free available chlorine on a daily basis. Just adding salt because you have a generator will not make your pool manage itself. In order to get the most basic chemistry under control, you need to test for alkalinity, calcium, pH, and free available chlorine.
If you do not have the ability to test these things, spend $10 on a 7 in one test strip that will give you this information.
Note: Chlorine generators have more negative aspects to them than positive. There is not a cost savings as advertised with these units. It actually costs more money, and takes more time to care for. The salt is very corrosive to the pump and filter system as well as the pool itself. The long-time cost would be cheaper to run a chlorine or bromine pool.
May 02, 2011 | Intex Automatic Salt Water System for ...
Excessive Scale build up on the Chlorine generator Plates. I Have to clean them every day.
Your water is WAY out of whack ... Please check all the chemicals including: Chlorine (ideal is 4 ppm), pH (should be 7.4), Alk (should be 100), Cyanuric Acid (outside pool only)(should be 60 to 80), Calcium (should be 350). Check the balance (see your pool supply company for the procedure to check). Get your salt to around 3400 ppm ...
If your calcium is high, the only way to reduce it is add water with calcium of a known low content of Calcium. If you have too much salt ... you will, again, have to dump water to get rid of the salt.
What about metals? Have you removed the metal from your water? Let the chlorine go to zero and add a sequestering agent ... follow the instrucitons on the bottle. You should add water only through a "bobby sox" filter to keep metals to a minimum.
I hope this helps you ... thanks for using FixYa.com
Oct 17, 2010 | Intex Automatic Salt Water System for ...
I have an above ground pool 18' round 52" deep. I purchased the intex saltwater system. I have had it run everyday for 8hrs a day and the ph is high and reads no chlorine. What to do?
Salt generating systems cuase pH to rise over time so you generator appears to have been working. What is the salt level in the water? Perhaps your pool is low hence no more chlorine generation.
Aug 27, 2010 | Intex Automatic Salt Water System for ...
Algae forming in pool
Chlorine generators will slowly raise the pH over time. You will always need to have acid ready to be added once the readings start getting above 7.6. You should try and maintain it down around 7.2 - 7.4 to allow for mistakes.
As for the generator; can you turn up the rate it generates chlorine? I am not as familiar with the intex but other brands have an adjustment knob to vary the rate chlorine is made.
Jul 27, 2009 | Intex Automatic Salt Water System for ...
No light on cell status on my chlorine generator
What brand of salt water chlorine generator do you have?
Have your water tested professionally at a pool store. Balance the pool water chemistry. Check the electrolytic cell for any calcium deposits on plates and follow manufacturer's instructions to clean.
Mar 18, 2009 | Pool & Spa
Pool & Spa Logo
98 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
