Question about Canon PIXMA MX320 Color USB InkJet Printer
When trying to print paper being pulled in at an angle so it jams
  • Canon Master
  • 4,338 Answers
This means that there is paper stuck near the internal paper feed rollers. Look inside and remove any paper that you see. Then take a damp cloth and clean all the rollers you can see.
Posted on Nov 15, 2010
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Printer reports that it needs to be aligned. However when I follow instructions to do so it doesn't fix the problem. The printer will print on a slight angle and then the paper jams when it gets to the end...
You seem to have a paper feeder problem, or the paper adjustments in the input paper tray are not set properly, if they are try cleaning all the feed and drive rollers you can get at. Try different paper.
Dec 14, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
When going to print paper is pulled in angled and jams thanks
i do not know the model of the printer that you have, but the most common problem is that you have something stuck in the area where the paper is not being pulled in. You might have a small piece of paper jammed in there or some foreign object. It is also possible your sensor is jammed and the paper is hitting it.
Lastly, if you have 2 pickup rollers (depends on the printer that you have), one could be worn out.
thanks adi
May 07, 2009 | Office Equipment & Supplies
Every time I try to print the paper jams.
check the pickup roller, make sure there is nothing preventing the paper from loading stright.
if all of the paper path are clear, then you will have to get a maint. kit to replace the roller themselves.
Mar 05, 2009 | HP PSC 2175 All-In-One InkJet Printer
Paper going thru at an angle and jamming
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Canon PIXMA MX320 Color USB InkJet Printer Logo
248 people viewed this question
old marine
old marine
