Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
My Brother MFC 257 CW will print but not scan. I cannot use the solutions listed above as the right links do noy appear when I try. When I try to scan it says 'check connection'
Mix-it-up
  • 832 Answers
SOURCE: Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Posted on Apr 09, 2008
  • 1027 Answers
SOURCE: HOW TO DELETE FAX MEMORY IN BROTHER MFC 640 CW
Unplug it.
Posted on Sep 01, 2008
BubbaGuru
  • 70 Answers
SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
Posted on Mar 23, 2009
  • 60 Answers
SOURCE: fax manual for brother mfc 490 cw
Go to http://www.brother-usa.com/Manuals/Default.aspx
Select Product and then model and download.
Posted on Aug 26, 2009
  • 31 Answers
SOURCE: Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Posted on Oct 22, 2009
I had the Brother mfc 490 CW connected to a lan network and it was working OK. Just two days ago I unplugged the printer and moved it to another spot in the same room connected to the same lan. When I...
Hello!
"No Station ID" means that your printer is in the mode "Transferring faxes to another fax
machine"
Brother has a Solutions Center.
I add a link to this center, hope it will help you resolve this problem asap.
United States Brother Solutions Center
May 30, 2017 | Brother MFC 490cw Color Inkjet...
I lost the CD for my printer(Brother mfc7420 all in one) I'm having trouble on getting the right download from the internet.
http://download.cnet.com/Brother-MFC-7420-Printer/3000-2116_4-81190.html
pls copy the link/url above and paste in your browser and lunch.a page would appear with the download button to the right driver u need
rate this solution afterward.
Nov 26, 2010 | Brother MFC 7420 All-In-One Laser Printer
HOW DO I PRINT AN ENVELOPE ON A BROTHER MFC 6490 CW
the plastic indicater should slide back and forth to adjustr from paper to envelope
if you dont have the manual to figure this out , go to this link
http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
leave positive feedback for me please
Oct 16, 2010 | Brother MFC 6490CW InkJet Printer
Won't scan
We need to first check the driver to make sure it is installed and working correctly. Please go to “start menuè control panelè scanners and cameras”.
(Note: For Vista users, you must select “classic view” in control panel to be able to see “scanners and cameras”)
You should now see all scanners currently installed.
If you do see your brother scanner, please right click the icon and select “properties”; here you can select “test scanner”.
If the test fails, select the “network settings” tab. Here you can have the driver set to locate the device by name or by IP address, please select IP address and make sure the IP address matches that of your brother machine.
To get the IP address on your brother, print out the network settings page; either with the “report” button on the printer or go “menuè print reports”
If the scanner does not appear in the list at all, you will need to reinstall the software. You can download the software using the below link.
http://welcome.solutions.brother.com/bsc/Public/CountryTop.aspx?reg=us&c=ca&lang=en
If your scanner successfully completed the diagnostic test, we can move on to try using control center to scan.
To access Control Center, please go to “Start menuè All programsè brotherèControl Center”.
In Control center, please make sure the correct device is being selected in the ”model” drop down list.
Thanks,
Pat
Mar 26, 2010 | Brother MFC 7840W Printer
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
No paper feed (brother MCF-440CN)
Had a similar problem with the MFC-885cw. Turns out that , if you have a photo paper tray installed which sits just above the main tray, you need to puill it all the way back towards you otherwise it blocks the paper feed. Not the best design feature I've ever seen.
Feb 20, 2009 | Brother MFC-440CN InkJet Printer
Unable to scan
I encountered the same problem (prints but won't scan) over a network connection. A download from Brother got it working again. The filename is BrRegDev.EXE and it is available free at:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000037/faq000637_000.html?reg=us&prod=mfc7220_us_as&c=us&lang=en
If the link doesn't work, try searching for the filename using Google (for example).
XP Device Manager still lists "MFC-420CN LAN #2" (even though there has only ever been one), but at least it scans now.
Mar 17, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
173 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
