Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an idea of what might be the problem? Thanx- JoeD
  • Philips Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Nov 15, 2010
    Problem Solver:
You need to chang the Blue and Green CRT Coolant. You can google it and find post of people that have done it themselves. You can order the coolang for about $12 a bottle and you will need three if you go ahead change the red.
Posted on Nov 25, 2010
LINES AT THE TOP AND BOTTOM OF PHILLIPS MODEL NO. 60PP9202/17F
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
The top rite and leaft of my screen coners are out
Wave would indicate your loosing high voltage and the tv is nearing the end. You can tweak hv, but its a short lived solution. Good luck
Jul 09, 2009 | Philips 60PP9202 60" Rear Projection...
Bent Picture at top and bottom
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Dec 13, 2008 | Philips 60PP9202 60" Rear Projection...
Philips Projection picture
You have bad convergence amps, tubes are fine unless you had a hazy looking picture before the convergence went out.To fix the haze the fluid in the picture tubes would have to be changed out.
Dec 10, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Picture problem
Convergence overhaul needed =====
1)Pull chassis
2)Replace Stk392-110 IC's x 2
3)reset alignment
  Usually a 400.00 repair at a tv shop......T.
Oct 18, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
575 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
