Question about Prestige Remote Start
I turned off the car and removed the key, then all of the dash lights began flashing and I heard a distinctive click, like the turn signal was on but it wasn't. The only way to get it to stop was to reinsert the key, turn the car on to "accessory," and then turn it off again. I have a remote starter. Could this be a problem with my remote starter? (This past week, the car did this and my battery went dead. Dead. Really really dead. I had to call a tow truck and get a new battery installed. While the car sat there "dead," the dash lights kept flashing on and off with the distinctive click.)
  • 139 Answers
There is a very good possibility that the remote starter is causing your problem. You should have it check by the shop that installed it. If the shop stand behind there installs, you should not be charged. I would suggest that the remote starter ground wire be checked to ensure that it is not loose.
Posted on Nov 16, 2010
My turn signals are wacky. Began w/both starting to flash then go off. Last niteleft arrow on dash on all the time and it flashes double speed w/left arrow on dash stays lit when signal is turned off.
Flashing too fast is typically a sign of a bulb out. Start with turning the 4-way flasher on, and walk around the car. All working? Bulbs ok if so, and that means replacing the flasher itself. Not an expensive part. The folks that change your oil are able to do that for you if you like.
May 20, 2015 | Ford Taurus Cars & Trucks
All the lights flash but the engine will not start
Find the security system and write down the make and model. Use internet to find owner's manual, or how to disable the system.
Jul 12, 2017 | 2004 Toyota Matrix
I have a 1987 chevy deluxe r10 dont have any turn signal I have head light brake lights park light an hazard lights but no right turn signal nor left turn signal I have check all fuses and put a new signal...
I think you might have a separate flasher for the turn signals under the dash. The turn and hazard flasher would look alike. Turn you hazards on and find the flasher for it under the dash. You will probably be able to feel it working and hear it clicking. The other flasher under the dash is for the turn signals. Try replacing that one. I think it was in later years they began to combine the two into a single composite flasher.
Mar 01, 2013 | Chevrolet Cars & Trucks
How do u diganose engine codes on a 1985 dodge 600 se 2.2
If you have an obd reader, there is a wire under the hood on the passenger side where obd connector can be plugged
Aug 26, 2010 | 1985 Dodge 600
1992 Cadillac Brougham 5.0 L V8 RWD, turn signal don't work.
The turn signal switch is most likely the problem,but change the flasher for the turn signals first,some times this is all that it is.
Jun 11, 2010 | 1992 Cadillac Brougham
Jump started car, dash lights flash and car won't start
turn key but all i get is a click from fuse box ,i check relays and starter and battery all ok
Jan 30, 2010 | 2001 Dodge Caravan
Turn signal makes the dash lights flash
97 chevy blazer left turn signal makes the dash lights flash then when i turn parking lights on left signal stays on constent when engaged
Jan 16, 2010 | 1995 Chevrolet K1500
1997 Suburban
Well it sounds like you have a short circuit somewhere. it apperars to be messing with the relay that you replaced. have you checked all the fuses in your fuse-box? how about all the bulbs on the exterior of the vehicle? try those things then post back.
Jan 06, 2009 | 1997 Chevrolet Suburban
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Prestige Remote Start Logo
178 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
