Question about Cycling
How do I remove the rear wheel from my bicycle? I think it has quick release but I don't know.
    President:
  • 1,514 Answers
1. If it has quick release it will have 2 plastic levers one at each side of the wheel axle. Otherwise there will be 2 nuts.
2. If it has the levers, Pull them out from the wheel. This eases the pressure on the nuts holding the wheel on the bicycle. Turn them anti clockwise to loosen them further. The wheel will then come away from the bike frame. (If it doesn't have the quick release levers just loosen the 2 nuts with a spanner)
3. Before taking off the chain draw a diagram or take a photo of how it's setup on the derailleur so you'll know how to put it on again. Pull the derailleur upwards to release the pressure on the chain and you will be able to remove it from the wheel.
4. All that remains then is to pull the wheel out of the brake pads.
Posted on Nov 15, 2010
2 Suggested Answers
  • 21 Answers
SOURCE: No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
Posted on May 20, 2010
Having trouble attaching front wheel. Owners manual or instruction sheet misplaced
How to install quick release front wheel on bicycle - YouTube
? 0:58
https://www.youtube.com/watch?v=xFx7UXyjW4Y
Dec 11, 2011 - Uploaded by Bicycles Online
When I went to reinstall my wheel my brake pads were stuck together and I don't know how to get them apart ...
How To Remove The Front Wheel of a Bicycle - YouTube
? 7:31
https://www.youtube.com/watch?v=BNwa0lONtbc
Jun 30, 2012 - Uploaded by cjhoyle
This is a quick tutorial showing how to remove the front wheel of a bike. ... Getting the lightly tightened other nut off shouldn't be aproblem.
Removing and installing your bicycle wheels - YouTube
? 4:06
https://www.youtube.com/watch?v=QslgCn9QX5I
Dec 25, 2015 | Cycling
Magna great divide
The Magna Great Divide does not have a quick release lever on the rear wheel.
Aug 02, 2014 | chitech Magna Womens Great Divide 24"...
Change rear wheel on the trek scratch air 6
put the chain on front side peddal on the smallest gear.
unlock the rear wheel and tap on side wheel whit your hand.
Nov 06, 2012 | Trek Scratch Air 6
How do i change the innertube in my rear tire
I think we can get you through this pretty easy. First release the rear brake. There should be a quick release at the brake it self or the caliper (squeeze brake and turn tab if it is there) One nut on either side of the rear wheel...should be 5/8th. You don't need to remove the nut just take it to the end of the axle on either side. Push the wheel forward while holding the de-railer all the way back. This will allow the wheel to drop down. That de-railer makes it look a lot more intimidating than it is. When you go to put it back on just hold it out of your way again. Be really easy if a person had three hands but it works with two.
Aug 10, 2012 | Schwinn Cycling
Quick release skewer
The end of the quick release that does not have a leaver on it is indeed a nut. You can unscrew that and take the "skewer" all the way out of the bike wheel. I would take my quick release axel out, place the coupler then replace the quick release axel through the bike wheel and then reattach the nut.
Dec 29, 2017 | InSTEP Quick N EZ Bike Trailer
I'm trying to change my rear tire , i have put the chain in the smallest cog in the rear, loosened the quick release but the tire doesn't want to come out. Do you have to do something with the...
If the quick release is truly loose, from the rear just lift the bike by the left side of the seatstay (or what would be a seatstay if itwasn't rear suspended) and rotate the rear derailleur backward with your right hand. It should just fall out.
Google "remove rear wheel bicycle" for lots of advice in video form.
May 20, 2011 | Cannondale Jekyll 800
How do I get a Raleigh Rapide (circa early 1980's) to hook up to this trainer? The rear wheel axle does not have a quick disconnect and I can't remove the axle to replace with the supplied skewer
A QR rear axle CAN be retro-fitted to your wheel by a bike shop and it would make wheel removal for repair much easier. If you DO go this route make sure to get an old-school rounded QR where the handle is not overlapping the end of the axle.
Like this: http://bicycle.guidestobuy.com/bicycle-components/shimano-dura-ace-hb7800-quick-release-2/
Just the same, won't the trainer grip the (assumed) nuts holding your wheel? It might mar the insides but I would think it would hold.
I just looked at the hardware on my old-school trainer and I think it would accomodate a 9/16" or 5/8" nut. I don't own any standard wheels to check it with.
Feb 19, 2011 | F2 Forza F-2 Magnetic Bicycle Trainer Bike
Cna't remove front wheel from my giant cypress bicycle
your wheel is either held on by a nut on either side of the fork or a quick release. In the case of the nut, you simply loosen both sides using a wrench and then the wheel will come off (the axle may have rusted to the fork so you may need to "persuade" it a bit with a rubber mallet). If you have a quick release, you unlock the release lever by pulling it towards you...you may also need to then unscrew the nut on the other side before the wheel will release.
May 24, 2010 | Cycling
May 20, 2010 | Schwinn Miramar Women's 21Speed Bicycle
I want convert from a regular threaded axel to a quick release pin on the rear wheel. How can I do that?
You will need to replace the old axel with a hollow quick release axel of the same outside diameter and the correct length to fit between the outside of your rear forks with the nuts and washers in place. In other words you will have to rebuild the hub of your rear wheel. It is arguable as to whether it is easier and cheaper to just buy a new wheel with the quick release axle already in it and just switch the cassette over. You will have to make a trip to your local bicycle repair shop for parts anyways so you might as well do a price comparison. Remember you will need bearings nuts washers and a tool to remove your cassette. Ask and they will probably switch the cassette over to the new wheel for you for a nominal fee. I used to charge $5.00 for this if the customer wanted to switch the tire themselves. It was an extra $5.oo to switch the tire.
Aug 16, 2009 | Cycling
Cycling Logo
102 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
