SOURCE: Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
SOURCE: F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
SOURCE: oven door
Peace
ngfam1 at your service.
Try turning the power off at the fuse or circuit box and then with it off open the door!
If no then turn the power on again and try to open the door!
There may be a section in the user guide too!
I am not there to give hands on diagnoses.
But I can give you a good service that is nation wide!
A&E Factory service .
They answer 24/7 to make appointments!
And have a reasonable service charge of $75 around our area
Remember though, if the unit is 10 years old or more it may not be advisable to
put good money into bad!
New appliances are much more efficient and pay for them selves in only a few
years!
Bless You,ngfam1
Please give me a good rating in our fiya.com sight before you sign off!
SOURCE: GE Hotpoint electric stove
If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
