Yamaha WF115 Series JAY2080 02049 67-94020054 G2 8 ohms It is an Eminence Tweeter driver. Blown ! I can not find a replacement
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: I have blown the woofers
Hi, i will recommend the Alto PS 5HA. You check to see the series of the Alto PS speakers on this LINK.........
Posted on Dec 16, 2010
I have a 15 inch powered Technical Pro speaker with a damaged audio board from applying too much eat trying to remove a bad transistor where can I get a replacement audio board
Shop for 15 inch powered Technic... on Google
Eminence Kappa Pro 15...
$154.99
Google Trusted StoreMusicians...
(5) Eminence Kappalite 301...
$209.99
Google Trusted StoreMusicians... Eminence Kilomax Pro P...
$239.99
(3) Eminence Kappa Pro?15...
$169.99
(3) Technical Pro zxp18 18 in. 4...
$151.88
Jet.com Search Results
    I have a 15 inch powered Technical Pro speaker with ... - Fixya
    www.fixya.com/.../t26013584-15_inch_powered_technical_pro_speaker
    1 hour ago - I have a 15 inch powered Technical Pro speaker with a damaged ... to remove a bad transistor where can I get a replacement audio board.
    Technical Pro Speakers ' eBay
    www.ebay.com/bhp/technical-pro-speakers
    eBayFind great deals on eBay for Technical Pro Speakers in Speakers and ... Package: (2) Rockville RSG12.4 Single 12" Three-Way, 4-Ohm Pro Audio ... Pro STAGE-212XU 3,000 watts Powered Speaker + 8 channel Mixer System + ... Technical ProPSHAKE1500 Two Way 15" Active 1500W Speaker Bluetooth and USB / SD.
    SA-15T - Seismic Audio Speakers
Dec 19, 2015 | Technical Pro power15usb 15 powered molded...
A replacement tweeter for Yamaha S215V speaker
I generally get replacements from Simply Speakers. Their site is-Replacement by Simply... Genuine Eminence Parts New
You can also just replace the diaphragm. The procedure is on YouTube here-
Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply... Genuine Eminence Parts New
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box.
Feb 17, 2015 | Yamaha S215V Main / Stereo Speaker
Where can I find a tweeter for Yamaha S215V speaker? Thanks
I generally get replacements from Simply Speakers. Their site is linked below.
You can also just replace the diaphragm. The procedure is on YouTube linked below.
Be sure you check what impedence you need. If you look at the lable on the driver it will normally say, but if not ask them about your specific cabinet. For instance the 8 ohm single 15" Yamaha Club Series 4 uses a 16 ohm driver in their 8 ohm box. Genuine Eminence Parts New Speaker Repair Yamaha Eminence Horn Driver Diaphragm Replacement by Simply...
Will an Eminence Beta 15A speaker (`5", 300w, 8 ohm) fit/work in the k3000fx? If so, will there be a trade-off or consequence of performance? I already own the Beta speaker, and have a chance to...
It ill probably work, however I have had to do body-and-fender work on a speaker cabinet where the new frame would not quite set in the existing hole in the mounting board. The Eminence speakers are supposed to be good... are you sure the Behringer amp is OK? The K1800FX uses a conventional linear amp... not sure about the K3000fx... The only possible problem I could see is that the original speaker (Bugera 15 inch)may have a different response and the tweeter may not match too well. You can probably adapt using th EQ should this be the case.
Sep 01, 2011 | Behringer Ultratone K3000FX Keyboard...
How do i tell if my problem if the high freq diaphram or the cross over
The crossovers in professional speakers don't fail that easily. It could be a blown tweeter. To confirm remove the metal grille-- remove the screws of the Horn Tweeter -- remove the cable connectors on the tweeter terminals ( Red and Black wire ). Now if you have a multimeter put it in Ohms range and touch the probes on the tweeter terminals-- It should show a reading betwwen 4 to 8 Ohms depending what is written on the back of the tweeter magnet. If you do not have a Multimeter you can take an ordinary cell/battery ( 1.5v ) from a TV remote and touch the terminals of the Horn Tweeter with the battery. + to the tweeter + ( a small red dot or mark will be there on the tweeter ) and -- to the tweeter -- . When you touch the terminals or give 1.5 volt supply the tweeter will make a scratching noise.
If you do not hear the scratching noise - it indicates a blown tweeter coil and will need replacement.See link below for spares:-
http://legacysoundservice.com/catalog1/product_info.php?products_id=1417
But if it does, you are in trouble and will need professional help from a electronic technician.
Could be blown HF Amplifier, suspect the crossover last. They seldom fail.
Revert back for more help
Apr 02, 2011 | JBL PRX515 Speaker
Is the tweeter a stand alone 8 ohm speaker?
yes, but it is attached to circuitry that allows only the high frequecies into it. You can replace the speaker with any 8 ohm tweeter without any difficulty, but if there is a capacitor across or in series with the speaker, make sure you put it on you new speaker the same way.
Mar 20, 2011 | Wharfedale Modus One-Six Speaker
No sound from tweeter bx5a
First of all, never connect the audio from your receiver directly to the tweeter. You can blow the tweeter instantly. The mid-bass driver can be damaged from a direct connection as well.
Since you get absolutely no sound from either driver, this seems to implicate the crossover. If the crossover has opened, no signal gets through, if it has opened early in the signal path.
But, it is also possible that a short exists, and that perhaps your amp cuts off the output having sensed a short. The short could be in the crossover or one of the drivers.
Here are some troubleshooting tips--
To prevent damage to your amp, turn it off while making or breaking any connections inside the speaker boxes.
Write down which wires get connected to which place on the drivers, so you can get them back where they belong.
With your amp turned off, connect the bad speaker to your amp. You've already verified that no sound is produced when both drivers are connected.
So, with your amp off, disconnect one wire from the tweeter in the bad box.
Briefly turn your amp on and listen for sound.
If you get sound, the tweeter is shorted.
If you get no sound, with the amp off, reconnect the tweeter in the bad box and disconnect one wire from the mid-bass driver.
Briefly turn the amp on and listen before turning the amp off.
If you get sound now, but not before, the mid-bass driver is shorted.
If you got no sound either way, check the DC resistance of the mid-bass driver (only, not the tweeter. Ohmmeters put out a small DC voltage to test resistance. That DC voltage might damage a tweeter, maybe. Don't risk it). Ohm the mid-bass driver while it is not connected to the crossover. If the driver is good, you should read some ohms--a little less than the stated impedance. An 8 ohm driver might read 6.5 ohms, for instance. If you get an open or a short (with the crossover disconnected from the mid-bass driver) you have a blown driver. Two actually, since neither the tweeter nor the mid-bass driver produced any sound in the previous tests.
If you can't get ahold of an ohmmeter, try this--
Open the good, working speaker and place the two side by side.
Connect your amp to the bad speaker box only.
With your amp turned off, disconnect the wires from the mid-bass driver in the bad box and connect them to the mid-bass driver in the good box. Disconnect one of the wires from the "good" mid-bass driver first, so you don't have two crossovers connected to it at the same time--even if only one of them will get powered on. It keeps the confusion down to a minimum when trying to isolate your problem. Oh, and disconnect one wire from the bad tweeter, in case it is shorted.
Turn the amp on and listen briefly before turning the amp off.
If you got sound, the "bad" crossover is fine, but the "bad" mid-bass driver is blown. And, since you got no sound in the previous tests, the "bad" tweeter is blown, as well.
If you got no sound, try it the other way around. Meaning--
With the amp off, disconnect the speaker wires coming from your amp from the bad speaker box and connect them to the good speaker box.
Your amp is now connected only to the good speaker box.
With the amp still off, connect the mid-bass wires from the good box to the mid-bass driver in the bad box. Remember to disconnect one of the "bad" crossover wires from its own driver first, so only one crossover is connected to the "bad" mid-midbass driver. Remember to disconnect one wire from the "good" and "bad" tweeters, so the only sound you hear--if any--is from the "bad" mid-bass driver, powered by the "good" crossover.
If this produces sound, but the previous attempts failed, you have a crossover problem.
If you still get no sound, something went wrong and you need to retest the good speaker by itself and back up a few steps and try again.
Assuming you got sound from the "good" crossover while it was driving your "bad" mid-bass, make sure no wires have come loose inside the "bad" box. Assuming you have sound connections at each end of each wire, you now need to desolder the electrolytic capacitors from the circuit board.
Make sure you mark them first, so you can put them back where they belong.
You can remove only one at a time, if that helps.
Use an ohmmeter to check some components.
The big red coil should read pretty close to a short, maybe one ohm.
The capacitors should read open or infinite resistance, although you might see a steadily increasing resistance while the capacitor charges up from the ohmmeter. If you read a steady low resistance on a capacitor after it has been removed from the circuit board, that capacitor is bad and must be replaced. The markings on the capacitor should give you some clues as to the proper replacement.
All things considered, I suspect that your problem is a shorted electrolytic capacitor. But, I gave you all I could think of so you can narrow it down and isolate the problem, whatever it might be.
I hope this helps.
Feb 23, 2011 | M-Audio BX5a Speaker
Tweeter not working on 15" EON G2
I have the same problem and the same conditions.
The tweeter is good, 3.8 ohms.
Some points of solding (donuts), have bad aspect.
I resolder the power transistors to the PCB and I solve the problem.
Jun 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
TweeTer Not working.
The only way I can think of to check is to disconnect the leads to the tweeter, then check resistance with an Ohm-meter...no reading means dead speaker.
Dec 28, 2007 | Car Audio & Video
134 people viewed this question
 Grubhead
Grubhead
