Question about Kohler Acorn Lift-Knob Flush Actuator Toilet Handles
I have the Kohler toilet with the top actuator, it flushes fine but won't stop running. If I lift the tank top I'm making the toilet flush again. Can this be fixed or do i have to replace the whole system?
  • 28 Answers
(Problem 1) if you can see the water running in the bowl it's a good chance that the flappers warn. you'll have to look at the angle where the light hits the water. The water will be rippling where the top of the water meets the inside of the bowl edge.
For more info on how a toilet works = http://www.aplumbers.com/residential/toilet
solution 1
1. tank the tank lid off.
2. flush, the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2 it could be the water levels to high.
(solution 2)
1. tank tank lid off.
2. if the waters flowing over the long tube in the center and down then the water level is too high 3. adjust the level either it will have a ball **** or a float in either case a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing. 4. adjust water level . 5. lift the flapper to allow a little water out til fill valve kicks on then release handle til valve stops . 6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Posted on Nov 17, 2010
  • darringtonja Jun 30, 2011
    That sounds like a pretty rough situation. What I usually do when stuff like that happens is I call a buddy of mine who has a lot of experience working in plumbing services and he comes over and takes care of it for me.
How do i replace flush valve?
To replace the ballcock (flush valve):
  1. turn off water valve at wall
  2. flush2 times
  3. disconnect line from bottom of tank
  4. unscrew nut where line enters tank bottom
  5. remove lift device (Chain) from stopper at bottom inside tank
  6. lift the ballcock up and out of tank.
  7. replace withnew
  8. reverse to install.
mike
Nov 14, 2015 | Kohler K-3453-K4 Memoirs Comfort Height...
Not enough water goes into the Toilet Bowl, The Tank fills up fine but very little goes into the Tank, Terrible Flush
THERE ARE LOTS OF SMALL HOLES WHERE THE WATER COMES OUT OF IN THE RIM OF THE TOILET BOWL, SOME TIMES HARD WATER BLOCKES THES AND THEY NEED TO BE CLEANED. THEY CAN BE CLEANED USING A LARGE SEWING NEEDLE, PUSHING IT INTO THE HOLE UNTIL IT FEELS A BIT BIGGER, YOU WON'T DO DAMAGE AS IT IS VERY HARD METERIAL. a
AFTERWARDS TURN OFF THE WATER, AND LIFT THE VALVE AT THE BOTTOM OF THE TANK AND PUT SOME TOILET ACID INTO IT. THIS WILL ALSO HELP CLEAN THE HOLES.
May 22, 2012 | Kohler Toilet - One Piece with Ingenium...
Our toilet Kohler 4634AA will not flush. Changed the flapper, followed the directions, etc. but still won't.flush properly...runs runs runs.
If the tank is filling with water to the line level, and the flapper raises, and stays raised until tank is almost empty, when flushed then it must be a clogged line. Try a plunger (toilet snake) and/or call a plumber.
Sep 04, 2011 | Home
We just installed the Cimerron two piece. After flushing the toilet, it will not stop running. Water just goes into the over flow section.
  • The exact cause of a Kohler Cimarron toilet running non-stop depends on the exact model of toilet owned. In some, the lift chain connected to the handle can become kinked, preventing the ball seal from covering the drain completely. Just unkink the chain to fix this. In other cases, the float ball is stuck against the side of the tank, preventing it from returning to its normal horizontal position. When this happens, the toilet's tank doesn't stop filling with water. The excess continuously flows into the overflow pipe. Dislodge the float ball from the side of the toilet and this should clear the problem. Likewise, you might consider shortening the armature on which the float ball sits, so it won't become stuck again.
  • Read more: Troubleshooting a Kohler Cimarron Toilet ' eHow.com http://www.ehow.com/how-does_5017443_troubleshooting-kohler-cimarron-toilet.html#ixzz1CxKmz9ZQ
    Feb 04, 2011 | Home
    After flushing, the water continues to run and does not stop.
    Lift up the back of your tank on the commode. There is a plastic float inside connected to a metal arm which has a chain connected to your flush handle. The chain probably came off.
    Aug 05, 2010 | Kohler Home
    Actuator/lever is broken
    well there is a ring just 2 inch up from butim of tank on the fluhmater ....you can twist it up and adjust your water
    Sep 28, 2009 | Kohler K-3422 - Wellworth Elongated...
    Push Button - Have to Hold Down Button
    I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
    Hope this helps
    Feb 18, 2009 | Toto Aquia II Dual Flush Toilet
    Kohler Acorn Lift-Knob Flush Actuator Toilet Handles Logo
    672 people viewed this question
    Top Kohler Home Experts
    Donni Steen
    john h
    Tim Whalen
    Are you a Kohler Home Expert? Answer questions, earn points and help others
