Question about Kenwood KDC-MP4028 CD Player
Protect comes up on my cd player
What does it mean. it does not play any music out of it what do i do?
    President:
  • 624 Answers
You may be able fix this problem by clearing the E2PROM. I have seen it a few times over the last few months.
press and hold the number 3 and the number 6 key at the same time and while you are holding those in, press the reset button.
The reset button is the tiny little depressed button on the display, you will need something like a toothpick or paperclip to push it in. You can also find it in your owners manual .
If this does not work you probably have an amp problem. That means you will most likely need to replace the amp IC.
I don't know why some of these Kenwoods do this, but I just started seeing at my shop about 6 months ago.
If this fixes your problem please feel free to rate me a "FixYa"
If you need further help feel free to ask.
Posted on Jun 19, 2008
Transfer music from my HP Laptop to my Walkman some songs on my Walkman will not play instead CANNOT PLAY LICENSE NOT VALID will come on screen, music is from my CD collection put on my laptop
The message means the music is copy protected and that means it will not play outside the device it was downloaded to, in your case the Walkman.
Feb 16, 2017 | HP Audio Players & Recorders
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
I have burned a .wma video file on a cd-r, on my computer it runs perfectly... only when i put it in my dvd player it say's stop and won't play. Can someone help me out ? Thanks Jeff
Several causes for non-playback:
1. Your CD player doesn't like CD-R
2. Your CD player doesn't recognize wma
3. The music you converted to wma is copy protected and the CD player wont play due to that.
Solutions:
1. Most likely this isn't the problem as most working CD/DVD players recognize CD-R. Double check with your user manual.
2. Check your DVD player's playback formats. Most will play mp3 and wav. If that's the case, rip your music to mp3.
3. There are many hacks out there to remove copy protection. This you'll have to figure out on your own :)
May 02, 2009 | Philips Televison & Video
I cant get music
Music - the newer Philips players do not support DRM-protected files. You will have to use songs that are in Mp3 format, or songs that are non-protected WMA's (NOTE: non-protected WMA's generally are only converted from CD's you own. I don't know of any music services that use them).
Video - the installation CD should have come with a program called the Philips (Arcsoft) Media Converter. If you have lost your installation CD, you can acquire this program from the Philips website. The program must be used to convert and transfer videos to your Philips.
-Tha Mp3 Doctor
Jan 19, 2009 | Philips GoGear Flash MP3 Player
Wont copy songs to mp3 player because of write protection
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Under this menu, you will be able to choose the type of music file as well as the quality with which you would like to save the music.
  4. Make sure the box next to Copy protect music is left unchecked.
Your GPX player has the ability to play music files in both the MP3 and WMA format. Make sure to use MTP when transferring copy-protected WMA files.
-Tha Mp3 Doctor
Nov 04, 2008 | GPX MW3836 MP3 Player
Wont regonize music
Reason could be because if you are no longer an "active' customer, the mp3 player can't go out and download the "permissions/rights" needed to play the song. As opposed to the songs you rip because you are using the cd for that, which means the songs are yours. At least thats my opinion.
Jan 02, 2008 | SanDisk Sansa e250 MP3 Player
Inability to play recorded songs
maybe the music you are trying to play is protected as many music you buy over the internet is. try loading your player with music you ripped from a cd or make sure the protected music is transfered directly to your player with the program you bought the music with.
Nov 01, 2007 | Philips SA3125\02 MP3 Player
Won't play songs
If you used Windows Media Player to copy the Cd's to your PC the default setting is to "copy protect my music". To change that go to Windows Media Player>Tools>Options>Rip Music and uncheck the "copy protect my music" box. You will need to delete the previously ripped music from your device. Then re-rip the Cd's and transfer them to your device. Best of Luck.
Sep 19, 2007 | SanDisk Sansa e250 MP3 Player
Playing a song?
Did you use your own cd's? If so, did you use Windows Media Player to copy (rip) them to your computer? Windows Media Player, by default, has "copy protect my music" selected. To remove this, in Windows Media Player select Tools>Options>Rip Music and un-check the copy protect my music mark. You will need to delete the music you already transferred, then re-copy the music without protection, then re-transfer them to your device. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e260 MP3 Player
Kenwood KDC-MP4028 CD Player Logo
59 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
