Question about Mitsubishi WD-62528 62 in. LCD Television
Reset lamp timer once lamp is replaced? from user manual for instructions-with no cost.
1. Press tv menu on remote 2. Select the setup menu 3. Select the lamp reminder option to reset the hours to zero
I hope this helps you.
Posted on Jul 11, 2011
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
How to reset lamp timer
The operator's manual has no reference to a lamp timer. The only user setting associated with the lamp is "Energy" for setting the lamp power to Standard or Bright. I'm surprised; most LCD RPTV sets have a timer that should be reset after replacing the lamp, and the instructions for doing so are given in the manual. The manual for this model only says to replace the lamp if the picture is getting dimmer (page 77).
Sep 24, 2012 | Mitsubishi WD-60737 TV
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
I have a Toshiba TDPT9 model. I replaced the lamp for new one. however, when turning on a yellow light is display (not fashing) and it does not turn on.
Diagnostic information can be found in the users guide or owners manual.
You can download the users guide from the toshiba downloads page.
This light most likely indicates that the lamp timer is overdue and needs to be reset. These instructions should come with your new lamp according to the owners manual. Usually this is a menu option on the projector with the 'reset to factory defaults'.
Feb 05, 2010 | InFocus ScreenPlay 4800 Multimedia...
I think my bulb blew out but I do not have an instruction manual and I'm not sure how to replace the bulb. Can I get a copy of the manual for the VIVITEK DLP TV RP56HD21-B?
Web site was no longer available last time I checked. HOWEVER...if you go to www.fixyourdlp.com they have step by step instructions. It is really quite simple. I have changes mine twice in the 5 years that I have my 56" Vivitek. Start out by unplugging the TV. On the back you will see 2 screws to remove the lamp door. Once open you will see the lamp holder which is also held in by 2 screws. Once they are unscrewed the canister and lamp can be removed. Use rubber gloves when replacing the bulb. You will need a phillips screwdriver and a needlenose pliers. There is one phillips screw on the side of the bulb to remove and a nut on top that needs to be removed. Pay attention to the 2 wires connected to these points and be sure to put them in the same position when hooking up the new lamp. Once the screw and nut is removed, you will see a spring clip extended from behind the lamp to the front of the lamp container. It clips in the front and the tention holds the lamp in place. Remove the spring clamp and the lamp will come out. Put your new lamp in place, replace the spring clamp as it was (This is the hardest part because of the tention of the spring and getting it back into the cutout **** for the wire spring), then replace the nut and phillips screw and you are ready to plug it back into the TV. Be sure to replace the lamp box properly. Look at the 2 wire connections and align it with the connections inside the TV. Once inserted, tighten the screws on the box, replace the lamp cover and tighten those 2 screws and you are finished. Plug your TV back in and turn on your TV. NEXT...remember to reset your lamp timer when finished. That is done with your on screen menu. Go to System Info and look for "Reset Lamp Timer". Once there, select "YES" to reset the timer to zero.
Nov 17, 2009 | Televison & Video
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Light does not come on -- we replaced the bulb--still dark
Sounds like the lamp timer has reached it's limit. In your users manual you will find the proceedure on replacing the lamp and reseting the timer. Once this is done the projector should work.
Jan 08, 2009 | Televison & Video
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Mitsubishi WD-62528 62 in. LCD Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
