Question about Craftsman Professional 20 in Drill Press
Need a torsion spring Part # 817685 for model sear 113.213211, Sears doesn't have it any more. Where can I find a replacement for it? thanks
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
bbreton
  • 437 Answers
SOURCE: I need a wiring diagram for the ignition switch on
Go to www.partsdirect.com. This is Sears website for equipment information. Put the model number in and it should find the model you are working on. A diagram should be available there.
Posted on Sep 25, 2009
Testimonial: "Thank you for you're quick response Robert Webster"
  • 15351 Answers
SOURCE: who sells craftsman parts besides sears?
check with any place that carries or repairs small engine or farm equipment call or bring model number they can cross reference the part number for other comparable parts some parts are craftsman only and they will be able to tell u also a lot of online companies carry many parts also
Posted on Oct 01, 2009
Testimonial: "Thank you!"
  • 78 Answers
SOURCE: I have a 9hp Tecumseh engine on my Sears chipper
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Posted on Oct 22, 2009
  • 6 Answers
SOURCE: manual for Sears Craftsman Home Sharpener 19071
my bet is you need to replace the belts, I posted the belt info. http://www.bobvila.com/BBS/Craftsman_Sharpener_drive_belts__out_of_stock_sure-Tools-1-F909.html#2827
part number 100XL037 1/5 pitch (XL) timing belt
you will need 2 of them, price was $4.21 a belt
very easy to change out 1 on a scale of 10 for difficulty. you have to know how to operate a screwdriver.
shipping was $6.68
phone is 951-677-7424 www.surfrainbow.com in California
Posted on May 03, 2010
How to replace a torsion spring to a mowing deck and defector ?
Go to the Sears dot com parts site and enter you model number. They will have diagrams that will help you. Model and year would be helpful. Hope this helps please post comment if it does.
May 08, 2014 | Sears Craftsman 46 in Mulching Tractor...
Torsion spring is broken for our liftmaster 2265R model garage door opener and i need a new one where do you buy one?
Here are instructions for replacing the spring. You can call any local garage door company and they will sell you the springs. I absolutely don't recommend this job for a DIY'er. It is dangerous.
http://ddmgaragedoors.com/diy-instructions/replace-garage-door-torsion-springs.php
Feb 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Have 1/2hp garage door opener that will not open the door. If the remote pad battery is dead will the opener stop working? if I press the remote opener the door move about an inch stops and the light...
Dead batteries will not cause your problem. If it is the main light flashing 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit to make sure.
Jun 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door gears misaligned
I got it... I moved the take up wheels that the cable wraps around to their outermost position and it's keeping the shaft from moving. kinda scary though, I don't like working around those torsion springs.
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have problems with the torsion spring
The springs are very dangerous to mess with the best idea is to get a professional.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Broken spring
call an overhead door company. the springs are under high tension. Better safe than sorry.
Nov 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Manual
http://www.liftmaster.com/consumerweb/service/manuals
Dec 30, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman Professional 20 in Drill Press Logo
210 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
