Question about Electrical Supplies
FG 5700 AK generator starts and runs perfectly but has no output electricity. A meter across the 120 volt outlet reads 1.1 volts. I assume the rotor needs some residual magnetism to start the generator, could this machine have lost the residual strength to where it cannot start? All windings and components seem to be ok and it was working a few weeks ago when last used. What can I test to know what is wrong with this generator? Thanks, Ted
  • Electrical S... Master
  • 10,831 Answers
Simple way to reflash the armature is plug a power drill into the genset, start genset, quickly turn the power drill by hand being careful to let go of it when it does turn on. this is a typical method for reflashing. good luck
Posted on Jun 22, 2017
3 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: I have a McCulloch FG-5700 (A or H) generator in
go to McCulloch Home
Posted on Nov 05, 2010
  • 122 Answers
SOURCE: model FG 5700 AK starts
there is a fuse or breacker that will trip some times so check that first, The wire may of came off from the plug in or the plug in will burn out some times or there is a diod in the motor they will go out you really need a meter to check these problems out just need to check the easy ones first fuse or bad wire good luck
Posted on Aug 04, 2011
How to increase the output voltage
Measure the Generator after 10 minutes the first measure but not only to one power outlet with doing a measure with a multimeter its not done so because the generator is fully unloaded then you will see 105 vac
Measure on one outlet and use a paint stipper a 2000 watt type and measure at the same time on the second power outlet with a multimeter on AC you should get more volts out to measure instead of 105 volts then you hear that its generate power and blow more smoke you will be seen a 115 or 120 volts if you increase this generator its possible you get if you are increase the idle power to 120 volt can create an over loading of 200 volt or more over the outlets that can give damage if it the stator electric field generate power outside its level it can blow up your expensive tools and in a short time you think there is not enough power on my tools anymore then your armatures are become bad and the tools are hot in a short time warmt dissipation has blow up armature and nothing smels hot but the tools are blowing up. and you see nothing inside because the tools will not are getting black burned and hot but the to high magnetic pulse burns the weak points inside the armature in a fraction of time.
Beware of that the adjusting is normally doing with a tacho meter and a suggestion of about 3000rpm and not more of the stator what its max depend on model . but adjust by the load power of a working paint stripper it can have enough if you adjust 120 volt by load.
Mar 06, 2016 | Electrical Supplies
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5754 4.8 kW 120/240 Volt PrimePact...
Homelite LR 4300 generator only supplying 230v, even at the 120 outlets
Make certain the voltage switch is set to 120 volts, not 230 volts.
If you lost your user manual, you can download on in the link below. Just click on the "open as PDF" button and it will download t your computer. http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/electric_generator.html?p=16
Dec 20, 2017 | Electrical Supplies
Generator does not output any power. Engine runs fine
I have the same problem and here is my troubleshooting steps I took.
1) Verified that the unit had no output with induction meter on cables coming out of top of generator head (three black and three white). You can use a volt meter too.
2) Checked that brushes were free and long enough.
3) Checked capacitor (condenser) was 130uF
4) Checked diodes
Sep 03, 2010 | Coleman Powermate Portable Generator...
On the outlets it has 4/120volts outlets and 1/120-240volts outlet. Can you use the 120/240 outlet as a reg 120volt? And what is the reason of the 120/240 outlet. Thank you
The reason for the 120/240 volt outlet is to be able to run things like large electric heaters or even your clothes dryer as they all require 240 volts. If you use it as 240 volts you will not have maximum current output on your other outlets so you wouldn't be able to plug anything really big in. And yes you can only use is as a 120V output if you would like but you will need a special attachment or extension cord. I'm going to leave you with two reference pages I looked up that you should have a look at.
http://www.powermate.com/generators/product_detail.php?model=PM0435003&cat_id=3&w=59
http://www.powermate.com/accessories/product_detail.php?cat_id=9&model=PA0650192
May 24, 2010 | Coleman Powermate Premium Plus 6250W...
Hi output from generator
I found out that the gasoline motor was turning too fast so I had to turn down the speed of the motor with the adjustment screw.
Sep 06, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
I plug a 1/2hp drill and use it I notice if I use anything else it is low of power. I put a meter on one plug and drill on other, and it reads upper 80-95 volts with drill running
Please check the owners manual.and see if the 6250W is surge power or steady state...it is not unusual..for this to occur...possibly the generator needs to be adjusted ( sped up slightly )..do not let the 120 volts output exceed 126 volts...
Apr 30, 2009 | Coleman Powermate Premium Plus 6250W...
Generator output
Hi, You don't say whether this is under load or not but if not is within the acceptable range, which is +/- 10% . Generally speaking, voltage on a generator is not the issue but the load which it will carry, hence their wattage ratings. Measure your household voltage and you will see that it varies from day to day but usually stays within the limits and your electrical panel is rated in amperage. Hope this answers your question!
Feb 07, 2009 | Coleman Powermate Powermate 5000W...
No electrical output
probably your AVR card is burnt...
an AVR card is located right outside the stator...looks just like an AK-47 clip (i don't know how else to describe it)...i put a pic below this.
replace it and check again
466fecd.jpgAVR location
168ff0f.jpgAVR card
Dec 28, 2008 | Electrical Supplies
Electrical Supplies Logo
464 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
