Question about Whirlpool RBS305PR Electric Single Oven
We ran the self cleaning cycle. Now the oven does not heat. Help.
  • 1 more comment
  • David Jones Nov 15, 2010
    Hey Daniel,
    I replaced the temp sensor, no change. Any thoughts?
    The model is RBS305PDB6.
    Thanks
    How do I check this switch? I just looked at it and when I move it to the right, the oven light goes off. When I close and open the door, the light goes on and off as expected.
    Previously, this morning, I ran the "clean" cycle for a few minutes and the door locked and unlocked as one would expect.
  • 4,323 Answers
Hi
When the oven does not heat the issue is with the oven temp. sensor that is bad and you need to replace it. You can test the oven temp. sensor for 1100 ohms and replace if the voltmeter reads less than this. Hope this helps...please post back for further assistance.
Daniel
Posted on Nov 15, 2010
  • 1 more comment
  • Daniel Scott
    Daniel Scott Nov 15, 2010
    Please post back with the model no so that I can help you.
  • Daniel Scott
    Hope you understand...both the bake and broil element can't go bad together so as the oven temp. sensor is already replaced, please check the door latch/switch if thats working fine.
  • Daniel Scott
    That was the correct way of checking/testing the door switch, you can also check these diagrams that will help you. Hope you understand...both elements won't go bad at the same time. If the door switch latch appears fine then it is the electronic control nothing else.
    Daniel
Hotpoint self cleaning oven clean light won't stop blinking
might need to run it through the cycle again. you may have disrupted the timers and if has not reset itself. try this link and see if these answers help you out.
Why does my oven light keep blinking after the self cleaning cycle on my...
Dec 02, 2017 | Hotpoint Ovens
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
My oven is less than a year old. I ran a self cleaning cycle on it and now it will not heat up. There is power to it because the light comes on inside. Do you have any ideas about what might be wrong with...
Self cleaning features on all ovens tend to blow fuses.
It is best to use a oven cleaner rather than the self clean feature.
Your oven has a fuse on the rear of the oven that must be replaced.
You must unplug the range and remove the rear panel to access the fuse.
Use a volt/ohm meter to check the fuse.
No reading on continuity is a bad fuse.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My built-in electric oven will not heat now, following the self-cleaning cycle I ran yesterday.
Frustrating no doubt. There are several things that can cause this and they vary by manufacturer and model. Sometimes the high heat causes a fault in the temperature sensor or its wiring. Other times it causes the control board to fail. We repair a lot of control boards that fail after a self-clean cycle. If you post more details: make, model, any other observations I may be able to shed more light. Or you can email me details at bruce@fixyourboard.com.
Best Regards,
Bruce
www.fixyourboard.com
Oct 14, 2009 | Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Thermador SM272 - Oven not heating after self clean cycle
Your repairman might be right but I would have checked the main heating element first for this reason: The self-clean cycle uses that same element as you need for the oven but is allowed to rise to a much higher temperature (~ 900-950 degrees) during the cleaning cycle and it may have self-destructed. Since your problem started after the cleaning cycle, I would have checked the element for continuity first.
Sep 23, 2008 | Thermador Professional Series PO301...
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Whirlpool RBS305PR Electric Single Oven Logo
97 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
