Question about Razor E300 Scooter
When i charge my e300s for 8 hours and plus. And when i ride it the battery goes back to low in 2 mins pls help.
  • 3,740 Answers
Hi and Welcome to FixYa, I am Kelly. You did not mention the age of this scooter or an estimate of the hours it was used. This sounds like the plates in the battery have deteriorated to the point that the battery must be replaced. Old batteries will self discharge do to corrosion or multiple re-charge residue that causes internal battery plate shorts or there is no longer enough plate material to provide the amperage necessary to operate your scooters motor. The only remedy is to replace the battery. If it is relatively new... then there can be a short in the chassis wiring. I doubt there is a short in the wiring as the controls seem to be functioning normally per your comments.
I have over 40 years of real world battery experience autos, aircraft, battery packs et al. This just sounds like the battery life has been reached and the battery needs replaced.
Thanks for choosing FixYa,
Kelly
Posted on Nov 14, 2010
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Apr 11, 2016 | Razor E300s Electric Scooter With Seat
Where can i get portable backup charge for mobilty scooter?
most scooter batteries take 5 to 8 hours to charge correctly the only backup methods are the following
if you have a detachable battery box .pride gogo ect a spare battery box can be purchased and kept charged.
there is no quick way emergency charge if you run out of power
just charge it evrey time you use it and for a min of 8 hours to keep your batteries in top condition,have them tested if you think low range.
Dec 06, 2014 | Health & Beauty
Month or two the riding Lawnmower tractors battery goes dead?
You can test the charger easily by connecting a remote charger for a few hours. Check the battery connections are tight and that it has water to the level a bove the plates. If the unit runs well for a while and then goes back to your problem the charger needs looking at. Some batteries get very low and then the chargers will not bring them back up. This needs either a new battery or external charging.
Jul 20, 2014 | Craftsman Garden
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
I get 8 flashes and it says it is a motor voltage problem. How can I fis it myself. I can't afford to take it to a dealer
you have to open the battery compartment and using a voltage tester measure the voltage output of the battery 12v output is stable if you measure a lower voltage then you have to recharge the battery after recharging the battery whethin a couple of hour and still low voltage on the battery then time to replace the battery.meanwhile if the battery is stable then you have to check the switch on the accelerator corroded contact can cause a poor distribution of voltage to the motor....you can post a comment for your additional question thanks! I hope this helps you..
Aug 30, 2010 | Golden Technologies Golden CompanioN II -...
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
Razor E300 Scooter Logo
136 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
