Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
I ca't open my WD passpor 160GB. It give I/O ERROR code how can i get my files from it?
  • 44 Answers
Look at this web and see if you could use the software there:
http://www.pcworld.com/downloads/collection/collid,1295-order,1-c,downloads/files.html
Posted on Nov 15, 2010
DVDR3575H doesn't recognize replacement HD
Unable to FORMAT the HDD in the device? Perhaps remove the drive - hook it up to a working PC temporarily, and using a partition software program or you could burn a CD (I use PartitionWizard), delete any or all partitions on the new 160GB WD and make that drive UNALLOCATED and UNFORMATTED. Apply the actions as needed - only to that drive (this will at least allow your unit to recognize it properly). Once done, remove the drive from the PC, and put it back into your recorder - see if it recognizes it this time, then try and format it (in accordance with the type of file system the unit uses - which may differ from that of a PC). Replacement drives should be formatted to suit the unit they are intended for AFTER they are fitted, not before. Otherwise you run into compatibility problems (e.g. the drive won't allow recording/doesn't read etc., but might work in a PC). If this is the case, it may explain greyed out options and not being able to record to it. If you still have the original drive, check the jumper setting to be sure. If both old and new are set to CS - leave them as is - don't change that.
Dec 18, 2017 | Philips DVDR3575H/37
Doesn't recognize replacement hard drive
What is the type of IC regulator voltage on power supply board Onkyo DV-SP502?
Jan 17, 2014 | Philips DVDR3575H/37
My WD does not show any stored contents at all such as photos, movies, and files. "Properties" show that how much space has been used, so I believe the stored data is not completely gone, just...
To find out if the files are indeed there just boot from a Linux Live -CD like
http://www.mandriva.com/en/downloads/one/
and connect - open the WD in it - if the files are still there just copy them elsewhere. If the files are missing then the file system has bee corupted. Boot back in Windows and run a recovery program like
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Recuva.shtml
Jun 17, 2011 | Western Digital Elements Portable 160GB...
Hello, i wanted to install NCsoft launcher but if i want to open it, it gives me an error Error Code: 13 (ProductConfigurationLoadError): There was an error loading the product configuration file...
ffirstly check out that the software which you are trying to install is compatible to your O.S. or not. It seems that it may be the compatibility issure.Get fesh copy of upgraded NCsoft launcher and then again try to install it.
May 27, 2011 | Computers & Internet
The I/O Error only occurs when I try to transfer some movies to my 160GB WD. I don't understand why, please help
It is possible the files are too big. Keep in mind that most external drives when they come from factory are using the "FAT32/16
file system which has a 4gb limit per file. You would need to format the drive to use "NTFS" instead
HOWEVER!!!!
FORMATTING ERASES ALL DATA!!!
You can right click on the drive under my computer and chose format to change it,
Hope this helps
Mar 13, 2010 | Western Digital 320GB MyBook External USB...
Cannot open file due to I/O device error!!!
dont worry, you can recover files from WD external hard drive, you need to follow the correct steps, here's a perfect data recovery tutorial for you
Recover files from External Hard drive
The tutorial is very easy to follow as I followed it to get back my files.
Apr 06, 2009 | Western Digital Passport 160GB External...
Cannot get automatic storage and update of files on to WD Passpor
There is a Backup in XP but its well hidden - go to Start, Programs, Accessories, System Tools and you will find it there. If not, it may not have been installed when XP was loaded on your system.
If you want to try something else, Google on " Free backup programs" - that should turn a few up.
Feb 02, 2009 | Western Digital Passport WDXML800UE...
How to open files on WD external hard drive?
You have to find it first by directing windows to the file . Right click MY Computer select explore select the drive letter C is your internal hard drive D is usually your CD/DVD.One you find the file double click on it . It will open with what ever program is associated with it
Jan 24, 2009 | Western Digital 160GB MyBook Essential...
WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link: http://www.wdc.com/en/products/accessories.asp?ProdID=170
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Oct 21, 2008 | Western Digital Passport WDXML800UE...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
196 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
