Question about Whirlpool DU1055XTSQ Built-in Dishwasher
I have a whirlpool quiet partner i dishwasher (model DU1055XTSQ2) that has suddenly stopped working. Control panel has partial functionality. All of the buttons on the control panel have a green LED feedback light when depressed. None of them provide LED feedback anymore except the Hi-Temp Wash, Sani-Rinse, and Heated Dry buttons. So there is power to the dishwasher. Any ideas? Please help Scott
  • Scott Marcoly Nov 24, 2010
    The control board arrived today and yes it is easy to install. However, this was not the solution. My dishwasher is still showing the exact same problem I had with the old board. What next?
  • Scott Marcoly Nov 29, 2010
    The control board arrived and yes it is easy to install. However, this was not the solution. My dishwasher is still showing the exact same problem I had with the old board. What next?
  • 15,935 Answers
The control board has failed.
CLICK HERE to see the parts breakdown.
CLICK HERE to see/order the part
Open the door & remove the 8 or so allen screws. The board is simply plug and play.
Bad design - the vent is right by the board - so its subjected to moisture.
Thanks!
Posted on Nov 15, 2010
  • nico_nyc Jun 01, 2011
    did you end up having any luck finding a solution for this, scott? we have the same dishwasher and the same exact problem just sprung up on me. it's been working perfectly until now. we are in brooklyn and we just had a very hot weekend with extremely high humidity, so maybe that had something to do with it, but i'm surprised a dishwasher wouldn't be engineered to handle high levels of humidity and heat... cheers. - nico
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
Whirlpool DU1055XTSQ2 Quiet Partner 1 Has grinding noise at start up. Can you send a diaghram so I can take off the bottom sprayer and what do you gthink it could be?
Is start up after filling with water? After it fills the wash motor starts to work. Some times the spray arm could hit the heating coil when it turns. Make sure the spray arm is not loose. But most likely its the wash motor.
Dec 12, 2011 | Whirlpool Dishwashers
I have a Whirlpool Quiet Partner dishwasher that stopped working
that is a typical indication of a faulty board. once replaced, i suggest a surge plug to be installed. it will protect the unit from future power fluctuations.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner 1 # DU1055XTSQ2
Read this article, it should address your problem.
http://fixitnow.com/wp/2006/03/20/whirlpool-built-dishwasher-includes-kitchenaid-and-some-kenmores-wont-start-clean-led-blinks-seven-times/
http://tclaundryrepair.com/
Feb 24, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
354 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
