Question about Yamaha NX-B02 Bluetooth Wireless Speaker
Bluetooth won't connect - Yamaha NX-B02 Bluetooth Wireless Speaker
Can not connect to a laptop
Could be the laptop needs a driver installing for it to work.
Conventional bluetooth and wireless needs a 2-way signal so the item you want to connect will appear in the laptop wireless and bluetooth menus and you can click on it and enter a password or pin number.
If the headphones don't appear in the menus you won;t be able to connect them. In that case you should refer to the headphone instruction manual.
Apr 16, 2016 | Bluedio Model R - Wireless & Bluetooth...
Bluetooth won.t connect
You may need to pair the bluetooth again as it may have lost its pairing id sync.
Delete the pairing if it exists and start from the beginning.
Apr 18, 2014 | ASUS MeMO Pad HD 7
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
My bluetooth adapter will not connect so have to keep my laptop connected to cable..any suggestions?
You mean wireless or bluetooth.
Because if you try to connect you laptop with a bluetooth adapter on a wireless network, it won't work.
They are to different technologies.
Aug 08, 2012 | Belkin F5D8631-4 Router (F5D8631au4A)
Acer extensa 4620 bluetooth peripherals drivers for windows 7 ultimate x64
You can only do it with a bluetooth dongle, it won't work otherwise.
Jul 06, 2012 | Acer Extensa 4620 Notebook
I'm going to assume..you've got an iPhone.. Simply because apple seems to have a "list" of approved blue-tooth items.
Unless your "JailBroken" (google only, please do not ask), if the said bluetooth device will not connect, consider updating your iOS to 5.1.1. or 6.0, or simply deal witht thefact..it won't work... Older deviices (3gs and prior) don't support things like A2DP (blue-tooth bi-direction communication, like a head-set)... and unless (jailbroken..see above about google). will simply not work.
If your NOT talking about an iPhone..you've got me.
Apr 08, 2012 | iPhone Apps
My bluetooth won't connect
you should make sure you are hooked up to a phone or computer and it will work much better. and if that doesn't work make sure the person your talking to has phone service. and if all else fails go to good old texting.
Mar 19, 2012 | Coby Kyros Android Tablet
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Good luck from Headsets Direct!
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
Yamaha NX-B02 Bluetooth Wireless Speaker  Logo
29 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
