Question about Refrigerators
We just picked up a table top icemaker that says ICEBOX on the outside and the numbers SA12863 on the back. It says it is supposed to have an ice basket but I'm not sure what it looks like or how to fill the unit with water. Is there anyway to get an instruction booklet or any other kind of help?
  • 35 Answers
SOURCE: Water not filling up the icemaker
it sounds as tho you do have solenoid prob.but it could also be an ice over sit at your water inlet tube that is situated near icemaker.
Posted on Jun 25, 2007
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
Posted on Jul 31, 2008
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
shustwit
  • 4 Answers
SOURCE: Mr Freeze SA12863 Counter Top Ice Maker parts?
Call the phone number on the back of the machine.
sunpentown 800-330-0388
They helped me diagnose a problem and sent me easy instructions for fixing it. They also had parts I could order.
Posted on Jan 07, 2010
iwillfixforu
  • 619 Answers
SOURCE: water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Posted on Feb 02, 2010
Refrigerator icemaker repair
The ice maker does its own thang. All it needs is power and a good water valve to supply the water. Also you paid the water bill helps too. Anywho when the temp in the ice maker mold drops below 25f the harvest cycle begins. The mold heater is activated and loosens the ice. When the ice starts moving the heater shuts down and the motor carrys over and drops the ice. The ice maker then asked for and gets water from the water valve. So what goes wrong? Watervalve solenoid burnt out, water valve dripping like a faucet make a stalagmite in the fill tube blocking fresh water to ice mold. If that is ok then something inside the icemaker went haywire, replace it. When replacing the ice maker replace the watervalve. Note: if temp inside icebox freezer does not get to 25f any ice maker new or existing ain't gonna make ice. Be sure to clean the coils down by the compressor and the kickplate so the maximum amount of airflow is running down there and make sure the cardboard panel back there is in place.
Sep 26, 2013 | Dryers
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
GE profile refrigerator pss266msra has a problem with the freezer. Replaced the thermistor and heater as suggested since I had ice buildup. Now icemaker is leaking water which is freezing into icicles -...
One of two things is happening.
1) the fill tube leading from outside the box into the icemaker may have ice buildup or is too close to the icemaker fill wall. Make sure there is a gap between fill tube and wall and check for ice in the tube.
2) wait for the icemaker to call for water and see how long is calls water for. It is only suppose to be 7.2 seconds. If it calls for water longer it can be overflowing. If overflowing than replace icemaker.
Usually there is ice buildup or something that the water is hitting and splashing everywhere.
If you have anymore questions or need more assistance please comment.
Aug 01, 2011 | GE Refrigerators
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Icemaker has stopped making ice. Freezer and icebox working fine.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 26, 2010 | Frigidaire FRS23R4A Side by Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Mr freeze sa12863 where does the water go.
you lift lid and add water up to the bottom of the plasticslotted tray where ice cubes will be after made. I have a problem with sa12863 also, The water quit filling into tray? like line is plugged or pump quit???
Oct 31, 2008 | Refrigerators
Apr 22, 2008 | Refrigerators
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
