Question about DSC Universal Accessories - P/N PTD1640U-CC
Cannot get clock to reset I tried *6code1 and time
    Problem Solver:
  • 8 Answers
Has to be the four digit MASTER code and military time. sometimes have to do twice. For instance. *612340800112310##
so that was *6 a master code 0800 for time and 112310 for date then hit # to save and # again to return to main screen.
Posted on Nov 23, 2010
The atomic clock did not reset to daylight savings time. How di I reset it?
Depending on which country you are in (the UK won't reset for a couple of weeks yet), your clock will automatically reset when it receives the adjusted time signal. If your clock is not receiving the signal, try moving it near a window and away from any electrical interference, or it is possible that your battery is getting low and has not got enough power to receive the signal.
Mar 08, 2015 | SkyScan 86709 Atomic Wall Clock
How do I reset the time on my Sharp Alarm Clock SPC 631?
Look for another switch that says "lock" somewhere. Move it away from "lock", then try the reset button. It's a shot in the dark.
Mar 08, 2015 | Audio Players & Recorders
How to fix Time-of-day clock stopped
Is it actually stopped or does it return to a default time when the laptop is unplugged for a while?
I assume you have already reset the clock, it's located in control panel under Date & Time. You can also set the clock in the BIOS.
If the time does not advance at all, your motherboard will have to be replaced as the clock chip is not replaceable.
If the clock just needs to be reset every time you use the laptop, you might try leaving it plugged in overnight to recharge the clock battery. If that doesn't help, the clock battery is bad.
Aug 21, 2014 | Dell Latitude E6400 Laptop
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Global atomic radio controlled clock
It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
Mar 16, 2010 | Audio Players & Recorders
How do you reset the clock on the microwave
press clear, press clock, enter time, press clock again.
Dec 09, 2009 | Microwave Ovens
Honda VFR800 Fi 2000 W Reg LCD clock problem
The problem is usually a weak battery. When cranking, it pulls down the system so much that the clock resets. Try puting the batt on a charger and start the bike to see if the clock resets with a steady feed of voltage.
May 17, 2009 | 2005 Honda VFR 800
The clock will not advance once it is set.
Try to change the timings in the World clock section and check whether it works or not.
Oct 27, 2008 | Palm Z22 Handheld
WHEN PRESSING COOK TIME OVEN CLICKS ON FOR ONE SECOND AND RESETS CLOCK
Please try on some other power point as if there is loose contact or sparking in point which cause to switch off as soon as you start because of heavy current drawn by oven and clock also resets. If not solved even then must have some short circuit or over loading in timer circuit or magnetron. in this case you have to call for a service engineer.
Jul 26, 2007 | GE JVM1860 Microwave Oven
DSC Universal Accessories - P/N PTD1640U-CC Logo
104 people viewed this question
Top DSC Home Security Experts
yobo007
yobo007
don1956
Level 1 Expert
Terry Weaver
Terry Weaver
Are you a DSC Home Security Expert? Answer questions, earn points and help others
