Question about Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV
How do i refit the seal aronud the lamp mount on my sony wega rear projection tv?
  • 179 Answers
SOURCE: 60 inch Sony Grand Wega
no, it is not the lamp,the DIC 2 board is bad.in this case it is best to have a sony certified technician come out to give you an estimate. the board is expensive and the lvds cables attached to it are verrrry
fragile and expensive also.
Posted on Feb 06, 2009
welcomejee
  • 10594 Answers
SOURCE: changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
Posted on May 02, 2009
welcomejee
  • 10594 Answers
SOURCE: What causes 900+ blue dots appear on my Sony rear projection tv?
Dot problem in Sony DLP TV caused by bad light engine (optical block)
Its costly part and needs qualified TV tech to fix it.
Posted on Jul 25, 2009
  • 556 Answers
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
Posted on Sep 11, 2009
SD Tech
  • 14553 Answers
SOURCE: I purchased the replacement lamp. I'm looking for
2004 Model Sony--
Unplug the TV set!
The XLU2100 LAMP IS accessed from the front of the set---you have to remove the front grill below the screen--if you look on the back on either side you will see a plastic knob you can back out by hand(Black)
Then you have to pull the grill off(it will resist this) start from the right and then the left as it is held in by several plastic pegs.
Usually there are some plastic tabs on the top edge so when you get it to release you may have to lift from the bottom to free it.
If you bought an original lamp from Sony it should have come with a allen wrench. Once the grill is removed you will see the lamp door-it is marked and usually only one or two screws.
Once you open and remove the door you will find the lamp--secured by two silver allen bolts--back the bolts out(they will spin free but not come completely loose) and with the handle on the cartridge--pull the lamp out.
Slide the new lamp in carefully and do not touch the face of the lamp with your hand--you need to make sure the two pin plug engages correctly when you do this--once in tighten the allen bolts down and put the door back on--set will not function if the door is removed!
You can at this point plug the set back in to see if it works---The lamp door must be installed or the set will shut off!
If all is good---align and snap the grill back in place and secure the two wheel like screws on the back that secure it to the case.
I do this here for free so if this information helps you please take a minute and give me a vote here---I am here to help people.
If you have any questions or need more help just reply to this posting here.
SD TECH
Posted on Sep 19, 2009
Sony wega/60 inch would not turn on,is it the lamp or some thing else.
The tv LED light "LAMP" indicator flashes or lite up?Tv Projection lamp been inside this tv like about 2 years already,tv on and in used everyday like 4 or 5 hrs daily?Yes,than the tv projection lamp life are ended and require tv projection lamp replacement.
Jun 15, 2011 | Sony Grand WEGA KDF-60XBR950 60" Rear...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Lamp light blinking on my sony 42" brvia wega what dose that mean?
The tv "LAMP"LED light indication flashes or stay lit.Yes.The tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Wega television has a red light flashing that says lamp
When Sony tv shows lamp light that means lamp inside tv is dead/ broken and need to be replaced.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
May 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replaced lamp in Sony Wega tv - Sony xl-2400. tv
hello make sure the lamp and the cover is fitted securely, when you've done this the tv should be ok
shaun
Nov 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My sony wega kdf-60-wf655 is blinking 7 times but when i try to start it, i ear some kind of power sound then goes off, i have disconnected evrything but still does not work
f-9308-750-0.jpgTHIS IS WHAT YOU NEED THE LAMP found behind TWO covers on side of tv one clips off the other needs to be unlocked by turning leaver and pull out this one is a SATETY COVER now reach in and lift the latch on the lamp and slide out REFIT AS REVERSE make sure safety cover is locked in place tv will not work if not ( LAMP XL-2200 )about £120 new
Oct 24, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Sony wega power problems
Replace lamp in TV as this is clear symptom of weak lamp and TV needsnew lamp, did you replaced lamp in 4 years? Lamp replacement procedureis written in user manual of TV, pretty easy job, make sure to buy Sonyoriginal lamp and avoid aftermarket/ cheaper/ alternative lamps for TVsafety.
Click Sony Support to download user manual copy (KDF-42WE655)if required.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Finding lamp in sony wega 50 in tv
Lamp is located in the back, Remove back it will be mounted in a box holding it should have handle to pull it out. For Parts Visit ENCOMPASS on line type in your model number it will lited parts to your set. or call Mats Electronics for Lamp 1-800-628-1118 Once you know Lamp # look for Deals on E-Bay.
Oct 02, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Off and on
I had this issue it cleared it self it was just after I replaced the lamp. I think the seal around the lamp mount was a little loose I removed it and refitted the lamp it has been ok since.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Changing the lamp in a Sony Wega KDF46E2000
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-60WF655 60" Rear Projection HDTV Logo
305 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
