Question about Brother MFC 8220 All-In-One Laser Printer
Reset Change Drum Error Message on MFC-8220 - Brother MFC 8220 All-In-One Laser Printer
4 Suggested Answers
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
SOURCE: dr-360 mfc drum reset
Brother MFC-7345n. DR-360 With power on and door open hold down the Clear/Back button. When asked new drum 1 for yes and 2 for no. Press 1 for yes to reset drum life
Posted on May 28, 2010
SOURCE: Just replaced the drum unit for Brother
Brother MFC 9180 change drum soon
Posted on Dec 11, 2010
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
6.Press Options.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
My brother mfc-8220 printer does not want to print. the drum was broken and i replaced it and the toner but yet i hear a grinding sound followed by an error message saying paper jam. I removed the paper...
it might be that the drum replaced is tighter or the space to pass with in the drum is less. friend did u replace the drum of a same model and same type?
May 12, 2011 | Brother MFC-8220 Fax
Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
How I clean Drum of Brother MFC 8220 Fax machine
If you mean drum reset
1. Open the front cover, and then press Clear/Back.
2. Press 1 to reset.
Oct 28, 2009 | Brother MFC-8220 Fax
Replaced the drum in our 8220, however we still receive a message to change the drum. Do we need to reset?
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum:
  1. Open the front cover.
  2. Press the Clear/Back key.
  3. Press 1 to reset.
  4. Close the front cover, pressing firmly on each side until they click into place.
Sep 10, 2009 | Brother MFC-8220 Fax
I changed the drum in my Brother MFC-8220 but the warning light will not go away. How do I make it go off?
Open the front door press and hold the reset key in.It will ask if the drum is replaced.select yes
Aug 17, 2009 | Brother MFC-8220 Fax
Cannot remove Drum on MFC-8220
When you open the frunt cover ther is a black hinge / leaver attached to the cover on the left hand side that disengages the drum unit drive, if this is disconnected / broken you will not be able remove the drum unit, an engineer may be required
May 16, 2009 | Brother MFC-8220 Fax
Toner empty error message on brother mfc 8220.
OK
Here's what you do if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Feb 28, 2009 | Brother MFC 8220 All-In-One Laser Printer
Brother MFC 8220 All-In-One Laser Printer Logo
346 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
