Question about Cameras
What is a "bayonet type
    Brigadier General:
  • 11,967 Answers
At one time, removable lenses for SLR cameras screwed on and off. Later, a "bayonet" type connection made it much easier for the lens to be aligned properly and changed quickly. A quarter-turn and "click"...it was in place.
Posted on Nov 15, 2010
Camera wont start kepps shutting down, message on screen says 'lens error, restart camera, when i do this saame message keeps coming up.
Depends on the camera make and type. If it is a DSLR, this usually means the pins that connect the lens to the body are not making correct contact. Try carefully cleaning and make sure lens is fully rotated into the bayonet. If a Canon camera, and this does not fix it, a repair can be very expensive...
Apr 07, 2016 | Cameras
Quantray mc auto zoom 70mm-210mm
Yes, if it is a K style bayonet, it will work - Pentax allows any K mounted lens to work with all their cameras from the K1000 from 1976 to the present... BUT - don't expect auto anything... including zoom or metering... but it should allow you to use it at least... Assuming the Lens is a K mounted lens... (you can't use it if it is a Nikon F or AI style, or Canon, or Minolta, which all use a bayonet style mount...)
Jun 24, 2014 | Pentax Cameras
Toyo 500mm lens to nikon d90 mount
At the risk of being obvious, you need a Nikon mount.
The lens comes with a T-mount. This is a "universal" mount with adapters for almost any camera mount, including the Nikon F mount. If the lens doesn't come with one, get a Nikon T-mount adapter.
The lens doesn't have any electronics, so you'll be shooting completely manual. No autofocus, no autoexposure, not even any exposure help from the camera's light meter.
Feb 23, 2013 | Konica Minolta Minolta Telephoto Camera...
What other brand lens fit this camera? Thank you. the camera is a P30 35mm
All Pentax bayonet mount lenses.(Third party) lenses:Vivitar,Sears,Tamron,Later Chinon,...In Reality almost all third party lens maker have produced bayonet mount lenses,and most of them are marked with a PK.Best third party lenses are Vivitar.Hope this helps.
Feb 07, 2011 | Pentax P30T 35mm Film Camera
Replacing NIKON 55-200MM BAYONET MOUNT RING PART. I have two of the three plastic guides broken on the bayonet mount. Can i buy this part and can i replace it myself. Sam
If it's the VR lens:
http://uscamera.com/jaa79851-b37.htm
If it's not the VR lens:
http://uscamera.com/jaa79351-f.htm
As to whether you can replace it yourself, can you use a screwdriver and a soldering iron?
May 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
Pentax ES2; do bayonet lens fit digital Pentax SLR?
Any Pentax K-mount lens will fit any Pentax DSLR. The DSLR will fire the shutter.  There is a menu setting (RTFM) which allows the use of older lenses, but you will lose some of the automation (again RTFM). Remember to allow that the effective focal length when using a "film" lens on a DSLR body goes up by 50%.
A standard 50mm lens becomes a 75mm equivalent, but stays a large aperture.
Nov 25, 2009 | Pentax ME Super 35mm SLR Camera
Spare part for Nikon 18-55mm vr lens
Part # 1C999-601-2 was the number Nikon said the part was called. It was used to replace the broken bayonet mount unit as seen in this step-by-step repair:
http://www.gmtruckhq.com/artwork-design-forum/how-fix-broken-nikon-dslr-lens-mounts-3271.html#post125961
Jul 16, 2009 | Nikon Cameras
Camera dropped an the lens broke off the camera
I have the same problem - the plastic bayonet lugs are the weak point on the lens assembly, but better that then breaking the camera body mating ring. I've dissasembled the rear of the lens and will try to reglue the two split lugs with cyanoacrylate glue. Be very careful not to mix up the 3 different types of screws, avoid damage to the multi-contact plate ribbon cable, and to not to loose the backfocus shims! Cheers.
Mar 15, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
