Question about LG LHD45EL Dehumidifier
Have LG LHD45EL dehumidifier whose fan locked up one day while I was away. Took motor apart, cleaned and oiled, but still won't run...not sure if it's bad motor, bad PCB, or both!
  • 2 more comments
  • srnett1 Nov 15, 2010
    Unit is~ 5 yrs old. Compressor is fine. Everything appears AOK, except fan won't run!
    Oops! Just put this in the wrong space: compressor runs fine. Everything appears AOK, but fan won't run
    Suggestions on motor testing? I have continuity with two of the leads, but none with the third! Thanks!
    This is a two-speed motor, with three wires, and I am aware that some motors require multiple connections to run...the wiring diagram shows: common, hi, and lo, so I am guessing that connecting 120 to the common and either of the other two should make it run...I have VOMs and test leads, so I don't need to cob...!!
  • 10,515 Answers
Kindly provide few more details :-
1. How old the unit is?
2. Do you hear any compressor noise when you turn it on?
Thanks!!
Posted on Nov 15, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Nov 15, 2010
    Thanks for your response!!
    It seems more like a faulty motor than PCB / control board. If control board would be at fault, you wouldn't be able to hear even the compressor running.
    Inspect and test the motor. Replace it with a new one and i am pretty sure you would be able to get it fixed.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    A quick way to determine whether the fan is faulty or whether the
    control board is failing is to put the fan motor on the work bench, make
    yourself a power jump cord by using a piece of lamp cord wire and put
    an electrical plug on one end and a couple of alligator clips on the
    other end. Attach the clips to the motor leads and plug it in. Be
    careful because the motor can actually spin if its not fastened down.
    You might even do this test with the motor mounted in the dehumidifier
    but have the unit unplugged and disconnect the motor leads from the
    control board. If this is not something you feel comfortable doing then
    you could try making a test cord from a piece of lamp cord wire with a
    light socket on one end and alligator clips on the other end. Clip the
    leads to the connector from the board that would normally go to the fan.
    Plug in your dehumidifier and see if the light shines or not. If you
    have a volt meter its even easier. I hope this will help you to pin
    point the source of your problem.
    Hope i helped you.
  • taran_2005
    I am sorry, i was not on desk...Did you sorted that...or would you like me to provide some details...I know you asked a question...but on sure, whether you have already sorted out or not....
    Thanks and Regards
    taran_2005
How do you check compressor on LG LHD45EL
If you just want to make sure the compressor is running, turn it to the lowest humidity extraction level setting, which is 35%. If the air intake filter is clean, and the water bucket is empty, the compressor should turn ON, in less than a minute.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | LG LHD45EL Dehumidifier
Our LG LHD45EL 45-pint Dehumidifier is not collecting water. The fan is running, and there isn't any error message in the display. I have tried unplugging it for a while to see if it would re-set....
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 14, 2011 | LG LHD45EL Dehumidifier
My LG LHD45EL all of a sudden
Short on refrigerant... or a failed compressor. are most likely or a system problem, causing it to trip off.
There may also be a failed electrical component, you need to check for voltage at the compressor.
cheers
Jul 02, 2010 | LG LHD45EL Dehumidifier
I've had the lg LHD45EL Dehumidifier for about 1.5 years now. I have used it every spring/summer. I turned it on this year and it runs but the water does not collect. Obviously something is wrong any idea...
I found the same thing. I've had my LHD45EL for 2 or 3 years. Worked great for my basement. This year I hear it run, but it doesn't collect water. I cleaned the filter and of course nothing. I took the back cover off, and tried running it. The condenser runs, but the copper tube leading up to the coil doesn't get cold. My guess is that the freon (or whatever refrigerant they are using) has leaked out. There doesn't appear to be any way to recharge it, the original tube has been crimped and soldered. Looks like junking it and buying a new one is the only option unless someone is good with a torch and solder. My question is whether to go LG or not.
Jun 09, 2010 | LG LHD45EL Dehumidifier
Unit is on fan not running
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Mar 31, 2010 | LG LHD45EL Dehumidifier
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
I have a LG LHD45EL and the compressor works, fins chill but fan won't turn at all. I took it apart and cleaned the armature of the fan, Used a non-contact device to ensure electric is present in the...
let the unit cool down
with power on try sticking something in there to spin the fan blade
if it spins and continues to work it is a bad capacitor (little shiny metal can sometimes oval or round)
if it doesnt spin i would have to guess the motor is bad
hope this helps
Jul 29, 2009 | LG LHD45EL Dehumidifier
LG LHD65EL Dehumdifier Fan Noise
It sounds like the fan has etached from its hub. This usually is not repairable if that's the case. Replace the fan.
Jul 03, 2009 | LG Goldstar LD65EL Dehumidifier
Dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
Sep 13, 2008 | LG LHD45EL Dehumidifier
LG LHD45EL Dehumidifier Logo
136 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
