Question about i-mate PDAL Pocket PC
How can i reinstall window on my device - i-mate PDAL Pocket PC
Serch google for
>imate pdal rom 6.1 then
>download the file from xda site
>connect ur phone to pc
>run the utility
Posted on Nov 24, 2010
Audio Device its Not detected
Have you done ALL the Windows updates? Is/was the Windows Vista a OS upgrade? Did the Laptop come with Vista? Take a look here: http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2353
Apr 26, 2013 | Gateway ID5815H-CA LX.WC502.003 Notebook
Windows cannot initialize the driver for this hardware code 37
Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 37 error, especially if the error is showing up on a device other than a BD/DVD/CD drive.
Important: If a USB device is generating the Code 37 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Apr 20, 2013 | Dell Inspiron Computers & Internet
Compaq Presario 2050NX onboard pnp nic (LAN) device not found - reinstalled onboard LAN device driver, still can't see it
For Windows XP CLICK HERE
In Windows 7 the driver installs automatically
I would suggest uninstalling all drivers for the network adapter then reboot and allow the system to find the NIC again. If this is Windows XP uninstall all drivers for the NIC, reboot, and install the above driver.
If it is Windows 7 uninstall the drive, reboot and allow device manager to locate the driver itself.
Nov 14, 2011 | Compaq Computers & Internet
Unable to detect cdrom after crash / reinstall Vista O/S
hpweb_1-2_minus.gifCheck the Windows Device ManagerDevice Manager is a Windows program that displays hardware devices installed on your computer that are currently recognized by Windows. If functioning properly, each piece of hardware has a corresponding entry in the Device Manager. If a piece of hardware is not listed, then there is a problem. There can be a variety of reasons, ranging from the easy-to-fix (such as missing or corrupted device drivers) to the more serious (such as broken or malfunctioning hardware).If your drive does not appear in Windows Explorer or there is no response from the operating system when you insert a disc, then you should check for an entry in Device Manager. This indicates whether there is a problem or not, and sets the stage for subsequent troubleshooting actions.To verify that the optical drive is listed in the Device Manager:
  1. Remove any discs that may be present from the disk drive.
  2. Click Start , type device into the search field, and then select Device Manager from the list.
  3. In the Device Manager window, expand the DVD/CD-ROM drives entry. There should be a name listed for each installed drive.If the drive is not listed or the DVD/CD-ROM drives entry does not exist and you have verified that it is listed in the BIOS , continue to the next troubleshooting item. reinstall the default device drivers Device drivers are software processes that allow Windows to use the computers hardware components. If the device driver fails or becomes corrupted, then Windows cannot properly communicate with the drive; in fact, it may not even recognize that the drive is connected at all.
Another common source of disk drive problems is that the correct device driver may have been inadvertently replaced with an incompatible one (for example, a generic driver for optical disk drives mistakenly installed by a third-party DVD burning program). In most cases, device driver problems like these can be resolved by reinstalling the default drivers and then installing any driver updates provided by HP. To reinstall the default device drivers:
  1. Click Start , right-click Computer , and then select Properties .
  2. In the System pane, click Device Manager link. If prompted, allow the computer to access the Device Manager.
  3. In Device Manager, click the plus sign c02993920.jpg (in Vista) or the arrow c02993921.jpg (in Windows 7) next to the type of driver you want to uninstall and reinstall (for example., Modems, DVD/CD-ROMs, and so on), unless a minus sign (-) is already showing.
  4. Right-click each listed driver one at a time and click Uninstall . When prompted, confirm that you want to uninstall the selected drivers. Do not restart the PC In the Device Manager pane, select any listed device and click the Scan for hardware changes button (near the top). Windows scans your system for hardware and installs default drivers for anything that requires drivers.
    1. Open Device Manager and verify that your device drivers are listed once again.
    2. After the device drivers have been reinstalled and appear in Device Manager, try running your program again.
      NOTE:Some devices may require your computer to restart. Windows will notify you when restarting is necessary. Save all open files and allow the computer to restart.
    If reinstalling the default drivers does not correct the problem, continue to the next troubleshooting item.
Oct 20, 2011 | HP Pavilion Dv6910us Notebook
I have no apple mobile device usb driver on my computer how do i install one?
Try reinstalling iTunes. Then plug in your device.
I'd start with the Reinstall the Apple Mobile Device Driver section of theFor Windows Vista or Windows 7: section of the 3. Verify that the Apple Mobile Device USB Driver is installed section of the following document, and proceed from there:
iOS: Device not recognized in iTunes for Windows
Sep 18, 2011 | Computers & Internet
Just reinstalled windows xp and now my creative labs soundblaster live! audio card is not detected. did all the troubleshooting in the hardware manager and it says the the device is working properly. did...
You could have a ghost device in the system. Remove the card and start the computer in safe mode. Look at the device manager to see if there are any sound devices detected. If so, delete them. Now install the card and let Windows detect it. You probably left the card in the machine when reinstalling the O/S. You shouldn't have any peripheral devices hooked up when doing a reinstall of Windows XP.
Sep 26, 2010 | Creative Labs Sound Blaster Live! 5.1...
Why does my computer says Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
usually if there is an corrupted driver windows will say,if you have the reinstall disk for that device good for you otherwise you might want to search the web for the latest,you might want to go in device manager and uninstall it restart windows,windows will tell you new device found and prompt for the disk or install automatically.
Good luck
Aug 26, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
Windows can't find any devices that are downloaded
take them all out and reinstall them one by one. check the my computer file and open the removable disks atleast one of them will have your camera files on there
Feb 21, 2009 | Sony PlayStation Portable (PSP) Console
Audio device erased
You have to reinstall your audio driver. Answers to your questions: 1. You can locate it in your Device Manager. Locate and expand Sound,video and game controllers. 2. You don't have to delete legacy drivers because reinstalling your audio driver will update it. Right click your audio software the one you found in the Device Manager and update it. It will find your installation cd of your system drivers. Else, manually install the audio driver.
*Drop me a comment if you still have questions. Your vote will be highly appreciated. Hope this helps you.
Feb 13, 2009 | Microsoft Windows XP Professional for PC
No sound device found
check for devices in "other devices" in Device manager
Oct 22, 2007 | Computers & Internet
i-mate PDAL Pocket PC Logo
52 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Bilal Ahmed Qureshi
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
