Tv shut off suddently. possible blown fuse. how can i fix it
  • 5,568 Answers
If there is no exposed fuse holder located near the power cord entrance, you will have to remove some section of the back to access any existing internal fuse.
Do this only with the power plug removed from the wall.
While fuses do die of metal fatigue (expanding and contracting of the element) it isn't that common and it may be a sign of more serious problems.
If you find one to replace, get two and if the first replacement fails again, save the other for the service tech.
Posted on Jun 19, 2008
TV turns on then turns off right away
In an answer to your problem, fuse could possibly be good and not blown
basing on your post "
TV turns on then turns off right away "
A fault or two have been detected so the TV will automatically shut off
to prevent further damage.
You will be needing tools, equipment , good vision and a lot of
patience when working with TV.
here is a troubleshooting guide should you need to DIY
Flyback Transformer
• Must have supervision of a qualified service technician
let us know if you need further assistance.
Sep 23, 2012 | Toshiba 32HFX72 32" TV
My tom tom one starts then shuts down. Can I fix this?
Sounds like your battery not charged fully. Check your charger unit , possibly fuse in plug faulty or cigarette lighter fuse in car blown.
Oct 14, 2009 | Tomtom ONE 3rd Edition GPS
My RCA big screen tv shuts off and comes on by itself.
on top of the fuse it sounds like the power supplie is going bad
Dec 03, 2008 | RCA P61310 TV
HELP
Your tuner is bad. You must have tuner replaced.
Nov 04, 2008 | Televison & Video
RCA MODEL #32V434T
Mine does the same thing I'm thinking a fuse has blown out and if taken to a tv repair shop or finding the right size fuse you can fix or get it fixed yourself..
Apr 10, 2008 | RCA 32V430T 32" TV
Sylvania Television shut down suddenly with a high pitch sound at the back
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
Figure on replacing the flyback transformer.
Hope ya fix it!
Jan 28, 2008 | Proton MM2701VT 27" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
TV just shut off one day...
This sounds like a PSU fault. Since ther is no way to determine your expertise then the best solution is to call an engineer.
Oct 06, 2007 | RCA F32632SB 32" TV
Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Toshiba TV Keeps shutting itself Off.
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 13, 2006 | Toshiba 36A43 36" TV
Televison & Video Logo
Top Televison & Video Experts
