Question about Kenmore Sewing Machines
Needle location on model 385.15516000
I can't find information on moving the needle on this machine. I have the instruction manual and it keeps telling me to make sure I have the needle in the correct position but it doesn't tell me how to move it. Can you help?
Thank you for anything you can do!
  • 323 Answers
Select the straight stitch and move the needle position by moving the zigzag lever or knob.
sewman7
Posted on Jun 19, 2008
My singer model is 6215c where can i get a free copy of instructions on how to set the bobber so it will move .and i need the needle size the needles that came withit keeps breaking.
Sounds like you need to have your machine professionally serviced. The needles that were included with your machine are not at fault--the machine needs to be adjusted to work properly.
Jul 08, 2017 | Singer Sewing Machines
Should I oil the motor on a kenmore sewing machine model 158.905?
Do NOT oil the motor unless the manual instructs you to do so. (Sears carries manuals for most of their machines.)
Your machine appears to be an older mechanical machine. As such, oiling would be necessary for the moving metal parts. The following may be helpful to keep your mechanical machine happily operating. (Although the following is for machines that have seized due to lack of oil, following the procedure is helpful in preventing the machine from seizing.)
Wheel on right side that controls the needle up and down is very tight...
May 06, 2017 | Kenmore Sewing Machines
My 6 head 15 needle baurden machine keep error message D1 then D3 I moved the needle bar but it won't move any more only to the right/ won't budge yo left. any suggestions I can. Help do
Check the troubleshooting section of the manual. Usually, there is a list of error codes and what they represent. May give you some information of what is amiss. Sometimes you can search the internet, input:
"Make" "Model" error code D1 or D3
Nov 20, 2016 | Sewing Machines
Which way does the needle go in on a 500A
Most Singer sewing machine manuals are available from their support web site: http://www.singerco.com/support/instruction-manuals . For most regular machines, including the 500 Slant-O-Matic, make sure that the needle take-up lever to the highest point with the hand wheel. Loosen the needle clamp screw and insert the needle with the flat side of the needle to the back of the needle holder. Keep the grooved side of the needle facing you. Make sure that the needle goes up as far as possible. The direct link to the manual for the 500A is http://www.singerco.com/uploads/download/1308_500.pdf .
I hope this helps.
Oct 28, 2015 | Singer Sewing Machines
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
I have a singer 6106 but no manual. When I press the foot the needle doesn't move although the outer wheel on the right hand side of the machine goes round. If I move the inner wheel on the right the...
go to http://www.singerco.com/accessories/instruction-manuals and type in your model number, then click "search" to locate the manual for this machine.
Sounds like the clutch is disengaged on your flywheel. Hold the outside of it and turn the inside bit away from you to reengage it.
May 28, 2011 | Sewing Machines
My Juki industrial machine will not pick up the lower thread and it wont keep a stitch going. Why wont it pick it up anymore!!! I really need my machine!
hi there
can you please tell me your machine model? i can help
any way if lockstitch machine you must first make sure you installed needle correct way and you are use new needle
can you check hight od needle bar is ok if you move it up and dwon?
can you check timing between needle and tip point for hook?
i can send page from instruction manual how to adjust hight of needle bar and timing with hook.
best regards
ashraf abozid
aabozid@hotmail.com
Sep 02, 2010 | Juki Sewing Machines
My xl-5700 the needle keeps breaking or the thread keeps getting all bunched up plus I lost my instruction manual can I gat a new one
About the needle problem, Brother's FAQ gives the following response:
Make sure the needle is correctly inserted with the flat side facing the back and pushed up into the machine as far as possible.
The needle could have been damaged or bent. If so replace with a new one.
Make sure the fabric is not pulled excessively when sewing. Let the feed dogs move the fabric. Do not pull the fabric.
The combination of needle size, thread size and fabric is incorrect.
Be sure to use the correct needle and thread size for the fabric you are sewing.(example: Denim-size 16 needle and 40-50 heavy duty thread).
As for the manual, here's the link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000063/ps21xl55565700ug02en.pdf
Dec 05, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
199 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
