Question about Car Audio & Video
Cd eject button returns error MSG eject failed; does not eject cd. No eject motor noise.
  • cromey421 Nov 15, 2010
    The mariner is a 2005 model with an AM/FM single CD, no cassette as found in the manual on page 16.
  • cromey421 Nov 17, 2010
    At the least, it matches what I was afraid it would be. So, it was helpful, but undesired. I do thank A for his help.
  • 11,800 Answers
Since the motor noise is absent and you get the message that the eject failed then there's only one cause that could do that: the ejection mechanism's motor has failed. It's a small 12 volts motor that can be replaced on its own. Unfortunately it has never been available as a separate part so the only source for it is another unit that is defective and can be used for parts.
If you can obtain one yourself, dismantle it completely and removing the motor to install in your unit, that would be perfect - it's a 4 hour very fiddly job.
Otherwise it will be cheaper just to replace the entire unit with another one.
Posted on Nov 15, 2010
  • 15,935 Answers
What is the make/model # of your unit please?
Thanks!
Posted on Nov 14, 2010
2008 santa fe 6CD Changer hows msg Initializing CD will not load or eject what to do?
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
2007 2009 HYUNDAI SANTA FE REPAIR MANUAL
Mar 09, 2018 | Cars & Trucks
CDJ-200 keeps ejecting disk without reading it. Tried to clean with a disk, and with compressed air, but it's still ejecting any CD that I put into it. It was working fine while I was mixing, and then just...
hii there,
Please also let me know if u get any error msg too. If dont get any
error msg. Please try to clean compartment of ur CDJ. But you have to open ur CDJ than clean it. If it does not work again. Then ur
CDJ need adjustment or alignment.
thx,
djajay
Aug 09, 2010 | Pioneer CDJ-200 CD Player
I have a 2001 ford escape. The cd player won't play cds it won't eject or load them. All it says is cd error
You have a mechanism failure on the changer which is preventing the mode of the function to return to the normal state. Hence the processor is giving out the error signal. First of all open the changer and ceck for mechanism damage. if not slowl try to rotate the load motor to return to the normal state and eject. now check the connections to the motor, the flexible line wiring may be defective. use a loop wire or test the continuity from the motor. if there is a rest switch use it for resetting, if not disconnect poweer nd power again. Some cd'smay be warped or damaged and causing to block the sensitive transport. remove of these cd's and testt again. if there is no motr drive at all then the IC of the motor drive has failed. clean and set back. hope this helps you. Good day
Jun 29, 2010 | 2001 Ford Escape
2002 Ford Exp Sport Trac - Pioneer 6 cd changer states cd error
CD CHARGE NEEDS TO REPAIRED OR REPLACED FIND A USED ONE ON COPARTS .COM
Sep 30, 2009 | 2002 Ford Explorer Sport Trac
I have a dell laptop, I inserted a cd into it with pictures, but no msg popped up to view the files. I tried ejecting it and every time i press the eject button nothing happens. I also looked under my...
Try opening Windows media player or iTunes and use the eject button from there to open the cd drawer (Full Mode>Menu Bar>Play>Eject).
If that doesn't work, try Fn + F10.
Also see this forum, which suggests some Dells have a bios issue.
In any case, have you tried shutting down the system and rebooting to see if eject function returns?
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 18, 2009 | Compaq Presario X1000 Notebook
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
CD Error
return it?
my first CD-500 had problems too. i just returned it and got a new one and the new one works perfectly.
it seems these stereos are hit-or-miss. i believe they are made in Malaysia now, not Japan, and that Nakamichi is not really 'Nakamichi' any more.
but i still love my CD-500.
Aug 28, 2007 | Nakamichi CD-500 CD Player
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
I receive error msg and cant eject magazine
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Nov 28, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
