Question about Mitsubishi WS-55807 TV
I have a WS-55807 that powers off immediately after it's turned on. I checked the trouble shooting code and the green flash blinked 2x repeated 2x and did that 4 times. What does that mean?
  • bnleaddogs Nov 18, 2010
    Thank you for your expert opinion. Now I need your advice. Letting you know that I do not possess the skills to fix it myself. If I was your Brother living in Wisconsin (too far for you to fix it) would you suggest saving the $300+ repair bill and use it on a new TV? or is fixing the TV a better option...especially since I spent $2,100 on it 8 years ago.
    Thanks for your thoughts....
    Brad
  • 10,515 Answers
The code 2-2 does indicates a short protect fault, which is usually caused by a failure in the convergence section. This is a very common repair in these sets. The typical repair involves replacing the convergence ICs (integrated circuits), and testing/replacing two small pico fuses.
The replacement ICs for your set are part number: STKxxx-xxx and are available from www.encompassparts.com for $19.95 each (needs two). You will also need at least one (likely two) 5 Amp pico fuses. If you wish to repair this yourself, the ICs are located on the large heat sink on the center (Power) PC board. The fuses are also on this board, near the center, location numbers: FXAXX and FXAXX. You would need soldering equipment and very good soldering skills to replace these parts.
An image of the same would be ( the below one is a generic picture ) :-
If you were to call a local shop to repair this, the labor to replace these is roughly $250-275 (in my area) if the TV were brought in to the shop. Please add a trip charge if repaired in the home.
The fuses must be tested with a multimeter to see if they are bad. They are only $2.50 each, so most people without a meter just change them both. If the repair has any problems, like a solder bridge, you may need a meter to check them after that. A good magnifying glass helps prevent solder bridges (for me, anyway).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 15, 2010
  • taran_2005
    taran_2005 Nov 18, 2010
    Thanks for your response!!
    I need few more details before i could tell you the best option. Kindly provide ALL the details :-
    1. How old is the unit?
    2. How many times it had been to repair?
    3. Total repair cost ( estimated ) till now?
    4. When did you last get it repaired?
    I would be able to tell you the complete analysis that we usually suggest on the basis of the details above. Waiting for your reply.
    Thanks and Regards
    taran_2005
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
When i go to turn the tv on the green light go on and then off. i did the coe test error code repeated 10 times
I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again
Jan 02, 2011 | Mitsubishi WS-55807 TV
My mitsubishi television ws-55807 went out while watching it, what can i do to solve this problem?
If power light comes on and then goes off do the self check this set has:
when light goes off and front of set press and hold both the menu and Input (device) buttons in at same time for at least five seconds and release both buttons.
The set will (the power light) blink a two digit error code like, 2 blinks, 2 blinks, a pause and repeat the code several times.
2,2 is most common error code, let me know what error code if any you find and comment here and I will tell you what it means.
The self check is designed to narrow down where a problem is.
SD TECH
Dec 04, 2010 | Mitsubishi WS-55807 TV
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Mitsu model ws-55807 power on for thre seconds then power off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
If you come up with the 2, then 2 blink code I have detailed START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET.
IF THIS has helped you, rate this solution as I do this here for free.
SD TECH
Nov 21, 2009 | Televison & Video
WS-55807
Good Day;
Shutdown at Power Causes: Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Sep 16, 2008 | Mitsubishi WS-55807 TV
WON'T STAY ON
That is a typical problem in the power supply. It could be a switching regulator that has i think 7 pins, but it gets the power supply up and running with around 157VDC. If that is missing the set won't power up at all. Where are you located. I'm in Louisville Kentucky. Let me know if that works for you. Keep in mind there are quite a few fuses in there too. so check those. I think on that model there is 7 or 9 fuses to check. Talk to you soon. Jay
Jan 14, 2008 | Mitsubishi WS-55807 TV
MITSUBISHI BLINKING GREEN LIGHT
I've got the blinking lights also. Model # WS-55613. Does anyone know what the problem is?
Dec 27, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
