Question about Microwave Ovens
Pressure cooker will not go to start once program is set! Timer switchess to E1 display!
  • Microwave Ovens Master
  • 2,200 Answers
You need to supply the exact make and model number of the pressure cooker first as different error codes apply to different appliances.
Thanks
Posted on Nov 15, 2010
My kenmore elite model 790.80373310 gave me E1 on display and then stopped working nothing happens just the countdown timer works
If you wish to get some details about microwave oven error codes; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 27, 2016 | Microwave Ovens
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Hi I am having problems setting the clock on my cooker could you please help thaankyou
HELLO.
solution on setting your microwave clock is explained below.
This is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
The microwave oven and timer must be off.
  1. Touch Clock.
  2. Touch the number pads to set the time of day.
  3. Touch Clock or Start.
Thanks.
Sep 21, 2011 | Microwave Ovens
Cook's essential pressure cooker has an E4 error. Tried everything and cannot get the unit to start
Make sure the inner container is dry... plug he unit off then on again.
Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle.
Apr 23, 2011 | Microwave Ovens
E1 error was shown on induction cooker.Please give me a way to solve this.
Possible that the driver of the induction coils is short or damaged. You might need to remove the panel and check within to see the reason for the protect cut off.
If there is no other display on switch On then the circuit is faulty and a knowledge of power electronics is needed to probe into the circuit.
Mar 16, 2011 | Microwave Ovens
Prestige Automatic pressure cooker Instruction
You really need the instruction manual for this model to provide you with full information on how to work it, however the recipes will probably be the same as printed in any other Prestige PC that works at 15/10/5 psi.
I have a copy of a 12 page brochure entitled 'Pressure Cooking - The Fact and the Fiction' that Prestige produced when this model was first introduced. In there there is one page of instructions and illustrations devoted to the Automatic. This gives the following four steps :
1. Put your ingredients in - and the liquid.
2. Secure the lid and set the switch. Turn heat up full.
3. When pressure is reached, set timer, move switch to AUTO, lower the heat.
4. When the bell rings, turn heat off - cooker will release steam automatically. Open and serve.
Hope that this helps.
Alan Vickers.
Feb 13, 2011 | Microwave Ovens
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
