On my Maytag Washing Machine...Sometimes my water selector works... sometimes it doesnt. Sometime hot will come out when set on cold and sometimes cold will come out when set on hot.. Sometimes it works correctly. What causes this and how do I resolve it?
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. Just reading this it sounds like the water temp selector switch is acting up. You did not provide a model number so this is just an outright guess to help you. Try this if you have the button type start mashing the buttons several times between temps. Do it with conviction. Your cycling the switch to unstick or clean off the contacts in the switch. If the cycle temp switch fails while doing this; changing the switch was the next recomendation to correct the temp problem. You should cycle the switch at least 30 times methodically. Press, change temp, press repeatedly. Then check your cycle water temps for hot and cold as selected. Depending upon model you could have a problem with the water inlet valve. I will wait for a response before commenting on that.
If you need specific model information I need your Model number.
Thanks for choosing FixYa,
Kelly
Posted on Nov 14, 2010
The water temp is opposite of the setting sometimes.such as the hot is cold and the cold is hot or warm
Has it been worked on ?
Sounds like the solenoid valve controller wires have been switched.
Jul 17, 2011 | Maytag MTW5700TQ Top Load Washer
Im installing a Maytag 412 top loading washing machine. Im not sure if it is the top input for hot or cold? Could you please help. Thanks, Tim
Without the complete model number, I'll have to inform you like this.
If it's red it's the hot inlet. Blue is the cold. If not colored. Normally the case has and H and a C stamped into them next to the corresponding inlet.
If all else fails do this. Hook up the water lines to either one. Now with both water lines hooked up and both the cold and hot water turned on. Plug the machine in. Use the selector on the console and set it to cold wash. Turn on and let it have time to turn hot ifit's going to. Feel the water temp. If it's warm or hot, swap the lines. If not, you have them correct. If the water is warm or hot, swap the connections. Good luck!
Nov 27, 2009 | Maytag Washing Machines
Have a Maytag washing machine MAV7600AWW.
sometime not always it wont spin also the water temp is more on the cold side
Aug 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Apr 02, 2009 | Maytag Washing Machines
Maytag washer/hot and cold water
Some whirlpool washers have had A similar problem. They had a intermittent water temperature switch issue. Sometimes they put hot water in when cold was selected. This is probably the same problem as yours. I would replace the water temp switch.
Mar 02, 2009 | Maytag LSE7806A Top Load Stacked...
Washer fills only with hot water
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Regards,
reg501
Jun 28, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
