Question about Dell 924 All-in-One InkJet Printer
Printer wouldn't work - said cartridge jammed - I took coloured one out - can't now get it back and the other one will not go into middle of printer for me to but the one back into position
  • 386 Answers
Hi Good daY!!! Check your printer if there is something that block your print head. after that turn off your printer and then move the cartridge into the center and then remove the ink cartdriges. after that turn on your printer without the ink cartridges, now your printer will recognize that your ink cartdriges is missing after that insert the ink (insert it properly) and then see if your printer would work now.
Thank you for using FixYa
Please accept if my solution helps you
Posted on Nov 15, 2010
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
Hp photosmart 3180 had a paper jam. I cleared the paper jam but now the lights are off and I can't get them back on, the only light flashing is the on and off button and that won't go on or off just...
remove the cartridges from the printer.then OFF the printer .then unplug the power cord of the printer from electric scource.then wait for one minute.then again connect the printer power cord.then ON the pinter .then before inserting the cartridges clean the brown colour dotted circuit of both printer and cartridge with a tissue paper.and then insert the cartridges.it should work after this.
Nov 20, 2008 | Office Equipment & Supplies
I have a canon mp730 printer. I ordered a new printhead for it after having printer problems. After I took out the old printhead to get a part number and reinserted it until new part arrives, I did a...
just start the printer by making it ON by pressing power button.as the printer moves slightly from its orignal set position remove the power cord as quickly as you can .so the head will be moved from its orignal position and after that there is a rubber belt in the printer which is black in colour just pull it slowly so the head will come nearer and nearer to you remove the cartridges as it comes in the exact position.
Sep 24, 2008 | Office Equipment & Supplies
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
Paper jam
hey, give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Lexmark printer x6150
I had the same problem and used Solution #3 (above) from a "Guest". Since I was only immediately concerned with printing in black, I took out the color cartridge and the printer is now working fine!
Apr 03, 2007 | Lexmark X6150 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
85 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
