Question about Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer
Inkhead clogged. Have tried deep cleaning several times. Cyan just won't print even though it is a new cartridge
  • Lexmark Master
  • 32,281 Answers
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Posted on Nov 14, 2010
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
I put in new ink cartridges and the cyan pink won't work.i have a lexmark prevail pro705.
Hello Rina! Welcome to FixYa!
If you have changed Ink Cartridge and after changing Cyan Pink is not printing then you may resolve this issue by Cleaning Print Head, Sometimes due to clogged print head nozzles this problem may happens. By cleaning the Print head Nozzles, This problem may resolve.
From the Printer Control Panel, Navigate to Maintenance, Press Up and Down arrow button to scroll Clean Print head or deep Clean Print Head and then Press OK.
Now try to print again. I hope this issue will be resolved
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Feb 14, 2012 | Lexmark Office Equipment & Supplies
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
Despite new cartridges I am getting a weird colour balance. Too much of a red tinge..almost as if the cyan cartridge is empty. I have utilised the cleaning and deep cleaning options several times but this...
I was getting green tinges for a long time and even though I cleaned everything it still happened. I had also used non genuine cartridges.
Eventually I took the cartridges out and gently wiped clean where the ink actually goes in and this worked. I have always been told that non genuine cartridges will ruin you printer?????? I now have all genuine back in and it works with no tinges. Was is the cartridges that clogged it - I don't know. But now that I know how to clean I will propably use the cheaper ones.
Sep 06, 2010 | Canon PIXMA MP610 InkJet Printer
Hello my 7590 printer will not print in cyan
The chances are you have a defective cyan ink cartridge. If you are using an aftermarket/reloaded cartridge and the cartridge chip is defective. First try a new cartridge. The best bet is a new OEM cartridge, run the deep cleaning utility 3 times. The nozzle may be clogged and this will clean the nozzle.
Aftermarket/reloaded cartridges ink do not always meet the specifications for the printers that use the finer inks.
Let me know if this works for you. Thanks.
Mar 07, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
My printer has stopped printing from the cyan ink
Hi, did you let the ink cartridge dry out completely before inserting a new cyan cartridge???
If this is the case you may have a bit of trouble getting the ink through the printhead...you have to persevere with deep cleaning and/or head cleaning...
if that does not work you may need a new printhead...which is usually dearer than a new printer...
I would also take the printhead out and clean the contacts with Isopropol alcohol...do not get finger prints on the contacts...that will stop it very quickly...
just a thought...did you remove the sealing tape over the airholes and bottom feeder hole on the cartridge???
if the airholes are sealed the cartridge pulls a vacuum and the ink will not flow...
hope this helps you...
cheers
haitchhcee
Dec 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer is catching on the bottom right section of paper when printing
when was the last time you changed the cartridge/inkhead could be ink buildup and causing it to snag Inkjets are horrible about drying and clogging. if inkhead is removeable you may take it off and clean the area that comes in contact or proximity to the paper, I would also check the bottom part of the roller and housing for anything that could be jammed in there or stuck.
Dec 22, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
463 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
