Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Green clean light flashes and dishwasher will not turn on
  • 10,515 Answers
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
SOURCE: green clean light flashing dishwasher
Mine worked on sani rinse and energy saver dry. Had a motor burn out that caused problem, and was really stressed when dishwasher wouldn't start after I put the new motor in. Thanks bunches!
Posted on Dec 30, 2007
SOURCE: the dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Posted on Apr 14, 2009
jsrock516
  • 5911 Answers
SOURCE: Green "Clean" light keeps flashing, dishwasher won't start
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Sep 15, 2009
SOURCE: The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
Posted on Nov 10, 2009
SOURCE: I have a Kenmore Elite
I tried everything, including cutting the power off, adjusting the doors, and on and on. The button pushing sequence sent my dishwasher into a diagnostic cycle. I let it run and after about 2 minutes we're back up and running! You would think the button pushing sequence would have been put into the owners manual, but I guess they want to be able to charge you a few hundred bucks to push a couple of buttons. Thanks to the responders and fixya.com!!!
Posted on Dec 14, 2009
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Green clean light is flashing, it will not clear and will not run because green light is flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 08, 2011 | Dishwashers
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Dishwasher won't reset, stays on gree-flashing light- Clean cycle
HI,
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
The dishwasher won't start, the clean light flashes green 7 times
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
try opening the door and closeing it to aknoldge you know they are clean and is there a lock symble under the green light
Feb 10, 2009 | Kenmore Dishwashers
GREEN LIGHT FLASHES
when the green light comes on open then close the door its to remind you there are clean dishes in the washer and opening the door acknowledges this
Jun 01, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwasher flashing green light
try to open the door and shut it that's supposed to acknowledge to the washer that you know the dishes are clean let me know if it works
May 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
91 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
