Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Spinner will not spin
Will go thru the wash cycle but when it gets to the spin cycle where the water is supposed to go out it starts then it stops whirlpool is it worth fixing it's 6 years old?
  • 246 Answers
For the cheapest solution, Un plug your washer. The tilt your washer forward and tilt the top back (about 45 degrees) until the top will stay balanced against the wall. As you look underneath the part closest to the front bottom it your pump. Imediately behind it is you motor. On the right hand side of your motor look at where the wires plug in. Have and of the wires come out of the plug or gotten burned? (there may be more than one plug down there for your motor) BE VERY CAUTIOUS. The black tube with the 2 red wires is your capacitor. If you touch an exposed area where the wires plug in it can give you a potentially fatal shock. So keep your hands clear of this or beter yet, use a screwdriver to short the two contacts together (make sure your hands are on the plastic handle only), thereby discharging your capacitor and rendering it no longer dangerous (until you plug it into the wall again). If all of these wires appear normal (plugged in and not burned) You would probably be looking at a bad motor.
Posted on Jun 19, 2008
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Top Loading Washing machine Stopped working mid-load
You may find a piece of clothing has jammed the lower spinner or the mechanism is worn and jammed up.
Mar 06, 2014 | Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Washing machine goes thru the wash cycle then it stops, if I lift the door it starts again ,than stops. lift the door it starts than stops
It could be your out of balance switch is getting tripped before you try it again put in the spin cyc and see if it spins and drains the water if it does a odd sized load could be causing the failure.
Apr 09, 2011 | Speed Queen AWN542 Washer
Machine won't go past "31" in the wash cycle. Does not code anything, just spins a bit, stops, repeats, stays on 31. I've posted two other problems with this machine in the past year. Have replaced a...
HopelessR
You may not want to hear from me again. This person had similar issues related to a Tub Seal and Outer Tub Bearing noise. I worked with him thru on a Outer Tub bearing, Tub Seal and Clutch replacement.
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/17706-neptune-tl-spinning-issue-will-not-proceed.html
“”Okay I will try to say what I have done so far. The washer keeps trying to go thru the spin cycle. It starts spinning & then stops & then starts up again, over & over & never finishes the cycle & doesn't expel the water.
NO codes come up as an issue either. “”
I did a lot of off line work with him via e-mail. I'm going to ping him and see if his machine is still in service.
Do the Quick spin test and see if the wash basket will spin up to 850RPM. Maybe we have some binding with increased Outer Tub Bearing resistance and or Spinner Support bearing resistance.................or it may be time for a plain vanilla $300 machine replacement.
Have you droped the clutch out to see if you have water contamination with the One-Way Roller Clutch bearing and Upper bearing ring. I believe you have a Series 10 machine.
Maybe someone else on the forum may chime in with a handy tip.
Let ya know how the other forum member fix is doing if he responds back to me.
D*ick
Aug 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Bosch dishwasher shu3032uc-14 doesn't clean very well tried different things but no help sometimes i can catch top spinner not working all the holes are clean where is the water level supposed to be and...
Pour a gallon of white vinegar in bottom run halfway thru wash cycle turn off let unit sit overnight to properly soak-then run a couple of times to rinse out vinegar(vinegar dissolves calcium which causes unit to not function properly) also check unit inlet for contaminates and clean as neccesary install inline filter if not one there..(the hot water tank will tell if you have a calcium problem(hard water problem)shut off unit undo relief valve on tank hook up hose to bottom then drain check for white chunks),calcium wreaks havoc on all household appliances and shortens there lifespan!!! :)
Jul 05, 2009 | Dishwashers
Washing machine stops on spin cycle
You need a new drain pump.
May 04, 2009 | Washing Machines
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal De
