Question about RCA P61960 61" Rear Projection Television
No power on RCA P61960 . push button on tv nothing, push remote nothing
4 Suggested Answers
  • 1694 Answers
SOURCE: tv repair
Please provide service number and chassis # from back of
set,then I can help.T.
Posted on Oct 13, 2007
Slapnuts1975
  • 51 Answers
SOURCE: "52" RCA Scenium DLP; No Picture and the buttons flash on and off
On the back of the TV, you'll find the Access door to your lamp. Unplug the TV from power, and remove the screw on the access panel. Inside you'll find 2 additional screws holding in the lamp housing assembly. Remove the screws, then the lamp assembly and visibly inpect it. You'll know if the lamp is defective, it will have obvious damage. If so replace with part # 260962, you can acquire this lamp for arround 100 dollars off ebay, or 262.00 direct from RCA.
Posted on Jun 04, 2008
SOURCE: constant blinking green power light but doesn't turn
This is from my WS65907 service manual.
4. Self Diagnostics
The “Power ON LED” provides an indication of the sets operation, and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is “24”, the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.5. Circuit Adjustment Mode
Most of the adjustments can only be performed using the remote hand unit. Many of the adjustments must
be performed in both the NTSC and HD modes. Video/Color adjustments must be performed in the NTSC
and HD modes, and data must be preset in the 480P (DVD) and VGA modes.
Posted on Apr 08, 2009
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
I would like to buy a rca 61 P61960
Hi jkclay841 i live new york and have a RCA REAR PROJECTION TV 61" MODEL # P61960 CHASSIS NUMBER PTK195Y06T
IT POWERS ON BUT IT'S OUT OF ALIGNMENT ON ALL COLORS AND MISSING THE CLOTH THAT COVERS THE SPEAKERS HAVE THE REMOTE SCREEN IS IN GREAT CONDITION ALSO HAVE SOME NEW CRT COOLANT RUBER SEALS ,AND THREE NEW LENCES THAT I WAS GOIN TO REPLACE BUT CHANGED MY MIND PLUS NO TIME.
HERE IS MY NUMBER 347- 847 -3348 IM JOSE
Apr 03, 2009 | RCA P61960 61" Rear Projection Television
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
P61960
I was tring to remove the concave off my screen and came across a setting where you can make the picture larger or smaller. On the TV, not the remote, press and hold the menu button, press and release the power button, press and release the volume up button and release the menu button. P0 and V0 will be displayed on the screen press the volume up button until the V0 is V76. Press the channel up button until P0 is P11 and press the volume up/down button to make the picture larger/smaller. If you need to center the picture press the channel down button until P11 is P10 and press the volume up/down button to center your picture. I hope this helps
Aug 18, 2008 | RCA P61960 61" Rear Projection Television
Rca model p61960 projection tv dead
More likely a bad flyback transformer......T.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Nov 04, 2007 | RCA P61960 61" Rear Projection Television
TV has a mind of its own
The front panel buttons are your trouble,you can disconnect these,first unplug the unit and remove the back cover,just below the top screws you can look under and see the top of the pictures tubes,in front of the middle tube is a small board,unplug the top right cable,this will disconnect the front buttons and you can use your remote to control the set,hope this helps
Mar 17, 2007 | RCA P61960 61" Rear Projection Television
RCA P61960 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
