Question about Video Game Consoles & Games
If a PS3 doesn't have a HD in it will it still work?
    Champion:
  • 207 Answers
Technically yes it will still work.. BUT thats as in it will turn on load to your correct hard disc not found screen.. if you need a new hd they are 30-40$ with caddy via me or ebay!
Posted on Jun 19, 2008
How come on my Elgato Game capture HD for mac i can never get audio comming through my computer on any system
1) Make sure your game console is set to output audio via the cables you are using.
Solution: The PlayStation 3 (PS3), Xbox 360, and other game consoles have various options for audio output. Make sure you have selected the right audio output option for Elgato Game Capture HD to use.
When using the PS3 with Elgato Game Capture HD, make sure you set the Audio Output settings to Audio Input Connector / SCART / AV MULTI
You can refer to this article for more details:
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
When using the Xbox 360, you can refer to this article:
http://support.xbox.com/en-US/xbox-360/audio-video-setup-and-use/configure-audio-settings
For an HDMI connection with your Xbox 360, try these settings:
1) Start the Xbox 360 console without a disc in the disc tray.
2) Go to Settings and select System.
3) Select Console Settings, and then select Audio.
4) Select Digital Output, and then select Digital Stereo My Elgato Game Capture HD doesn
Jun 21, 2014 | EyeTV Elgato Game Capture HD High...
Tip
How to Enjoy HD Movies on PS3 Freely
PS3 is a kind of HD device, specially designed player for high-definite video such as HD MTS, HD M2TS, HD MKV. Enjoying HD movies on PS3 will achieve the most clear results, highest visual and sound quality.
In order to freely enjoy HD movies on PS3 players, the first thing you have to fix is to convert HD movies to PS3 supported format. The key solutiong for converting HD movies to PS3 is Aiseesoft HD Converter which can help you convert HD videos to PS3 in an easy way.
Free download and then follow this guide to convert HD videos to PS3 so that you can enjoy HD movies on PS3 freely! For Mac user, here is HD Video Converter for Mac
Step 1. Add Files
Run and load HD moveis by clicking "Add File"
Step 2. Output Settings
Select the PS3 supported format as follows:
Tips: With this step, you can also convert HD Video to Xbox 360, Convert HD Movies to iPhone, Convert HD RM to iPod, etc.
Step 3. Start Conversionw
Start to convert HD Movies to PS3 by clicking "Convert", now you can enjoy HD Movies on PS3 freely! Download this HD video converter and have a try with it immediately!
on Jul 26, 2010 | Computers & Internet
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
My problem is earlier today i was playing my ps3, the picture was showing on the t.v. ( a HDMI Cable conected it to the tv), but 30 minutes later, i tried to play my ps3, the picture was not showing up...
Sounds like your video settings are wrong. Since you were on the HDMI connection the video was outputting in HD. When you switched over to normal AV (composite) cables the video was still outputting in HD.
Simple fix: power off your PS3 (so it's in standby; red light is showing). Then turn it back on, using the power button on the console (not the PS3 controller) and hold down the power button until it beeps a second time (about 5 seconds). The video settings will reset to composite. If needed, change your video settings.
Normally I'd put down like 3 other things it could be (each worse than the last), but I'm fairly certain that this will fix it. If it doesn't, just say so and I have many a more potential fix available.
Hope it works!
Sep 24, 2011 | Sony Playstation 3 (PS3) Console
NEED HELP HOOKING MY PS3 COLOR STREAM CABLES I HAVE MONSTER HD CABLELS
If the ps3 is connected and it doesn't show on the tv, unplug both the tv and the ps3. then plug them both in and turn on the tv first then the ps3 by holding the power button of the ps3 for about 10 seconds before it beeps then it should show up on the tv screen.
May 16, 2011 | Toshiba 46UL605U LCD TV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Ps3 only works on my HD tv.
when you turn on the ps3 from the switch on the back, when the light turns red, hold down the power button on the front instead of tapping it to turn the light green. Hold it for atleast 5 secs. This restores the display settings.
Feb 20, 2010 | Sony Video Game Consoles & Games
When I unplugged the HD cord my playstation3 does not work. It only works with the HD Cord
if you are trying ti use the standard PS3 cable going to the videoinputs on a tv the PS3 needs to be reset turn off the playstation by the switch hold the power button and turn the switch back on hold the button until it beeps this puts it back in standard mode, when the PS3 uses the hd cable it automaticallly sets to HD mode but fogets how to get back to standard mode
Jan 18, 2010 | Sony Playstation 3 (PS3) Console
HD cables not working on ps3
you can get hd picture only with hdmi cable
Jun 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Video Game Consoles & Games Logo
22 people viewed this question
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
