Question about GE Microwave Ovens
We have a GE model # JVM239BL. We started to use it and it shut off. We have no lights on the display. The outlet it is plugged into is still hot. Any suggestions?
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave not working
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may send you a replacement magnetron. GE Customer Service is here.
Posted on Nov 25, 2008
  • 389 Answers
SOURCE: GE Spacemaker 2.0 Model JVM2070SK02 no power - I
You need to find a handy dandy fellow or lady and take the back off. You may need a special screw driver type tool in the allen wrench catagory. The screw may have a post in the center. They carry these type of allen wrench tools at the hardware store. Get the kind that has several different sizes on it It cost a little more but you won't be sorry later.
Once you get the back off you should see a white fuse. This is the first thing to check. You may not have that amperage of fuse laying around the house in your drunk drawer. Just to test it out wrap some aluminum foil around the fuse and plug it in and if you get power on the lights then that is your problem. Unplug it until you get the right fuse at the same hardware store. You don't want to have any sparks flying or wires burning. The aaluminum foil just gives you a temporary test at best. And it is also all I can offer you in help on microwaves. Except to check and clean your fan while your inside of it. Let me know if I got lucky and please leave me a thumbs up for the effort. Raz
Posted on Apr 23, 2010
GE Microwave (Over the Range: Model HVM1540DPBB) was stopping operation. It would beep, and the display would show garbage. I would unplug it, then plug it into the outlet, then it would display "keypad...
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 02, 2013 | GE Microwave Ovens
EVM1750SMS has No power. Outlet is good
press the start/off button for 3 seconds see if it displays locked, if it does press again for 3 seconds to unlock then press the clock button and follow the prompts.
Mar 07, 2010 | GE EVM1750 Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave starts after plug-in cannot be stopped by control panel
This seems like a problem with with the door latch circuitry HW. If the unit is still in warranty, call GE customer care. If not, your neighbor will need to buy a new oven. Service on microwave ovens is not cost effective because the replacements are so reasonable and have so many new features.
I have a lot of experience with these units. If the door latch circuitry is in question you may be exposed to dangerous microwave energy. Hope this helps...
Ray
Nov 20, 2008 | GE Microwave Ovens
Cuts off after 2 seconds
Just a hunch; plug it in to a different outlet.
AC outlets are only marginal when new and that unit can draw well over 10 amps.
If the contacts are failing, the unit will think it has been disconnected, killing off the clock setting too.
If that doesn't help, try plugging another high power appliance, an iron, toaster or coffee maker, into the same outlet used for the GE to see if they behave normally.
Jul 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM2070 issue
what is the make and model number
Mar 26, 2008 | GE JVM2070 Microwave Oven
Microwave wont come on at all.
replace the fuse. You have to remove the top grill and then you will find it above the display
Dec 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
181 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
