Question about Inter-Tel Encore Phone
Intertel Encore CX - phones will not initialize and cannot connect via MPS software
I'm looking for help with the above system.
Installation and maintenance manual indicates that on power up the power LED should be solid and the vital activity LED be flashing.
Unfortunately for us no vital activity light.
Hmm ..... where do we start?
  • graphics777 Apr 22, 2009
    My phone system had the same problem. No vital activity LED and only a very dim power LED. Followed rocket99's solution and got very close. Changed all 4 capacitors on the main board and even found an identical one blown on the power supply board which was changed also. Now I have a solid (and bright) power led, but the vital activity LED will stay on solid for several seconds, turn off for several. It will then come back on for several seconds, then turn off, followed by two flashes of the very bottom DSP LED. Then the cycle repeats. The power LED stays on the entire time. Any help would be greatly appreciated.
  • 3 Answers
There are 3 capacitors on the the mother board that blow. You need to completely disassemble the unit down to the main board. The main board in held in place by 3 screws, then needs to slide to the left to free it from the case. Carefully pry it to the left using a flat blade screwdriver.
The capacitors are underrated for this board, and I use a capacitor with a higher voltage rating to replace them. You can get these from Radio Shack, P/N 272-1030, 470uF 35V.
The ones that usually blow are the 3 on the bottom left of the main board. They are in a vertical row, and you can see that the top of the capacitors "puff" and have a little dome on top of the capacitor.
Replace the capacitors, and reassemble. The 35V rated ones are just a little bigger and you may not be able to push them down to the board all the way, but no worries, it will fix your problem. We are a dealer for this product and found that every one that we install, failed with the same problem.
I should mention that there is another capacitor just to the right of these 3 that may also fail. Again, look for the top of the capacitor. If it is not perfectly flat, change it.
Posted on Jan 09, 2009
Try down powering it...wait...ignition...see what happens...just a suggestion.
Posted on Jul 17, 2008
The installation cd for encore 802.11g wireless adapter has been lost. how can i install?
you will need to go to the manufacturers website and download the latest drivers and software nad install them onto your comp. If you do not have internet access you may need to use another computer and copy the software and driver files onto your comp.
Nov 06, 2009 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
It cannot detect the wireless detection
Hello Friend
Below is the link of User manual of Encore wireless router ,
A short reading of topic "Installation setup" of Wireless router Manual will give you a cross check from your configuration setup.
http://www.encore-usa.com/download/manual/ENHWI-G2_Manual.pdf
, Also check your Wireless Receiver card is properly working or not
Sep 06, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
Screen says initializing
try formatting your device and upgrade the software using the firmware manager that came along with the device in the installation cd. hope your problem will be tackled
May 26, 2009 | RCA M4204 MP3 Player
Admin changes on encore cx
You can actually do the system programing thru the phone itself, press the prog button above the display on the phone & go to system programing, you'll need the system admin code (try 1111).
Alternatively you can install a programing applicatrion on your pc & connect to the async port on the main control unit. The program applicaion would have been delivered with the system docs.
Mar 05, 2009 | Inter-Tel Encore Phone
Speaker phone indicator will not go off
Liooks like you have the phone programmed to "Handsfree answerback" this will cause the handsfree light to flash continiously.
In this mode the phone will auto answer any internal call from another extension.... so watch out.
To switch this mode off press the program button above the displey & you be given th option to switch "Auto Answer off " I think it's the first option, try it.
Jan 07, 2009 | Inter-Tel Encore Phone
Fail to initialize hardware!ErrorCode#E0601
esse erro leia o manual la ta escrito o porque deste problema por isso o brasil nao via pra frente
Dec 29, 2008 | Encore ENLTV-FM (EN-LTVFM)
Inter-tel 660.300 Intertel Premier 24 Button
Line could be dead from local provider (Verizon,etc.).Could be a bad port on the phone system. Maybe a bad connection into phone system. What Intertel system do you have?
Oct 16, 2008 | Inter-Tel 660.3000 Intertel Premier 24...
Intertel phone system died
Look for power on the InterTel system, any kind of lights on the system is an indication you at least have power to the system. If you are plugged into a power strip and have no lights, remove the power cord from the strip and plug it directly into an AC outlet. Be sure to turn off the system before plugging it into a wall outlet, and then turn the system back on. Good Luck
Aug 03, 2008 | Inter-Tel ECX 1000 Telephone
Interel voice mail rings
In System Timers change the System Forward Initiate timer. Be cautious that this is a system wide timer and will affect all users. If you want it done just on one phone it gets a little bit more complicated but it is still possible.
Oct 26, 2007 | Inter-Tel Axxess Corded Phone
Change Time and Names
On your Intertel Encore system you can program from a phone at extension 20. Intertel does not allow the sale of the manual to end-users (you) only Intertel dealers have access. I can help with the time change: From EXT 20 press the PROGRAM key, use the arrow keys to scroll until "System Programming" is displayed. It will ask for the password. The default is 1111, if it's been changed you may be in trouble... You would then select "System" then Select "Time and Date" - change the time (24 hour format) and date (MMDDYY) then hit the SPEAKER button to complete programming. I hope this helps. I have not done this myself, just passing on the instructions.
Jan 30, 2007 | Inter-Tel Encore 618.4001 Phone
Inter-Tel Encore Phone Logo
825 people viewed this question
Top Inter-Tel Lands Phones Experts
george  peters
george peters
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
