Question about Sewing Machines
Machine wont pick up bottom thread - Sewing Machines
    Genius:
  • 1,788 Answers
Try a new needle, make sure that the flat side faces the rear of the machine. Hope that is the problem, or you may have to take it in for service for the timing. Good luck
Posted on Nov 15, 2010
Thread not picking up the bottom thread
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread!
If it is still not picking up the bobbin thread, then the machine may be out of time. Search for sewing machine timing or take it for service.
Make sure the top tension is set appropriately--the default is the midway point and then tweak it for your particular machine.
May 21, 2017 | Sewing Machines
My brother pe150 embroidery machine does not pick up bottom thread and wont sew
try changing the needle
rethread the machine--use every thread guide
make sure the bobbin is not warped
make sure the bobbin is inserted correctly in the case
it's very possible that the timing of the machine is off & the machine would need to be checked at a sewing machine shop
Mar 20, 2012 | Brother Sewing Machines
My needle wont pick up the bobbin thread
Hi. The most likely cause is that your needle is inserted backwards. There is a flat side on the shank of the needle and this flat side has to go in facing a specific direction (usually away from you, toward the rear of the machine) so that the needle can form a loop with the top thread to pick up the bottom thread. Some machines, especially older ones, require that the flat side be inserted facing right, or facing left (I have one of each), but in my experience most modern machines need the flat side of the needle shank facing away from you.
Sometimes, if the needle is in correctly for your machine (check your manual to be certain) and still isn't picking up the bobbin thread, the needle could be bent.
Check these out, and let me know if they solve your problem, ok?
Happy Sewing!
Robbie
Mar 03, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Top thread doesn't pick up the bobbin thread (Toyota sewing m.)
Hi! This may sound silly, but if you changed your needle and put it in backwards (which is easy to do), the top thread won't pick up the bottom thread. Take your needle out and check the flat side of the needle shank--which way is it facing? With a lot of the newer machines, the flat side goes to the back, but check your manual to make sure.
Let me know if this helps, ok?
Happy Sewing!
Robbie
Feb 12, 2010 | Sewing Machines
Wont pick up bobbin thread
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
Oct 02, 2009 | Singer 7444 Mechanical Sewing Machine
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
Singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Dec 15, 2007 | Sewing Machines
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
