Question about HP Photosmart 3210 Printer
I downloaded software yesterday to make my 3210 all-in One photosmart printer compatable with windows 7 operating sx on my new pc It is printing fine but can't get the scanner to work. My email is mlpedrizetti@comcast.net but I'm on my husband, Fran's pc with email below
  • HP Master
  • 5,126 Answers
There are a couple of issues that can cause this. 1) Did you install the full software before you connected the USB cable (if you are using that connection)? If not, did you uninstall the generic software and remove the data cable before installing the software? Try a new data cable and a direct connection if you are using a print server or USB hub. Scanners require bi-directional communication and will fail even when the printer works.
Are you launching the scans from the computer or the scanner? Try launching the scans from the computer first. Remember you need to set the destination button defaults in the HP software and the monitor program needs to be running to see those button presses. Try scanning with Windows Fax and Scan (New Scan) or Paint (File > Import from Camera or Scanner > New Scan).
Navigate to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=439488 and select your OS version (32- or 64-bit Win7) and click Next. Then look in the section Utility - Diagnostic Tools. Download and run the HP Scan Diagnostic Utility. Also check if you need one of the Update patches (there is one for scan files going missing).
If you are using the unit as a networked printer, also try a new data cable. Make sure the router is not dropping packets and that your firewall isn't blocking the incoming signal from the scanner. (Try scanning with the firewall temporarily disabled.)
Check if the unit has a scanner lock and unlock the transport lock if it is in the incorrect position. Check if the lights come on and the unit moves when you try to launch a scan. If the lights aren't coming on or the scan unit doesn't move, the unit probably needs service.
I hope this helps.
Posted on Nov 14, 2010
Have new HP Windows 7 (64 bit) laptop and have old HP Photosmart 7850 printer without softwre CD. Printer is recognised by the computer but I've changed cartridges and cannot align the them as have...
If you ahve teh software installed, right click the icon and select the properties option then locate the tab that has the option to run in compatibility mode. Set the software to run in Windows XP or Vista compatibility. If it is stopping the installation, right click the installation file and tell it to run in compatibility mode with a previous version of windows to install.
Jun 18, 2011 | HP Photosmart 7850 InkJet Printer
Can't run on windows 7
Go to the HP web site and download the software. Choose whether you have the 32-bit or 64-bit OS here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&os=219]&product=439488 and click Next. The driver will be the first option and the second link will let you order a new CD with the drivers. If you plugged in the USB cable before before installing the software, you should uninstall the generic driver and then unplug the USB cable before installing the software.
I hope this helps.
Jun 10, 2010 | HP Photosmart 3210 Printer
HP Photosmart C6280 not visible as printeroption though installed
this will usually happen if you're disconnecting the USB cable from the computer and putting it back on a different USB ports. try to connect it to where it was working before. this is also true for other USB devices such as scanners and webcams
Mar 13, 2010 | HP Photosmart C6280 Printer
Replaced old laptop with new HP-dv8t running Win 7 pro. Downloaded and installed HP Photosmart 2600 software for 64 bits. HP Solution Center says printer is not connected but I can print, scan. Under...
windows 7 install software for any printer automatically
i use hp 2100 and hp 1608 printers with windows 7 without installing their software
if your os is not recognizing the printer than you need to download theupdated software compatible with windows 7 of your printer
Feb 05, 2010 | Computers & Internet
Hp photosmart 3210 software is not recognizing
If that's the case the best way to resolve this is to download the printer software and use that in installing the printer to your Vista computer, you can download the printer software from this link.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=439488
Feb 02, 2010 | HP Photosmart 3210 Printer
Is my HP Photosmart 3210 printer compatible with Windows 7?
Yes. You can obtain the new drivers and software for HP Photosmart 3200 series printers from HP support page for your printer.
Just select your system language and Windows 7 version to get a list of available downloads.
Dec 19, 2009 | HP Photosmart 3210 Printer
Running Vista and printer will not talk to cpu, I downloaded drivers and reinstalled all 3210 software please help!
chek ur printer driver whether it is compatible with windows vista or not go to hp website and download the proper driver update for vista.
Sep 07, 2009 | HP Photosmart 3210 Printer
Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Jul 20, 2009 | HP Photosmart 3210 Printer
HP Photosmart will not Scan.
Please click on the web link given below and download the scan diagnostic utility.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-45265-1&cc=us&lc=en&dlc=en&product=439488
If this does not fix the issue, please contact HP chat support, this support is free of cost.
Click on the web link given below.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Nov 15, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
