Question about Husqvarna 125bvx Hand Held Blower Vac
The leaf blower will start, but it stalls when i push the throttle
SOURCE: i have an echo gas powered leaf blower, model
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Posted on Apr 10, 2009
  • 398 Answers
SOURCE: homelite Backpacker II leaf blower start fine then
have you checked air filter? the carb may need adjusting. locate the adjustment screw(s) , screw them all the way in then back out 1-1/2 turns. try to start the engine. then let me know what happens.
Posted on May 17, 2009
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Posted on Jun 12, 2009
Smooth_Gecko
  • 125 Answers
SOURCE: The engine on my Red Max EB7000 backpack leaf stalls or smothers.
Two things come to mind.
One, the tank cap is not allowing air into the fuel tank to replace the fuel that is going out. This results in a vacuum in the fuel tank until the pump can no longer **** fuel. Test this by running it with the cap loosened a little bit just to test it OR loosen the cap after it has stopped and see if it goes normally again.
If this doesn't do it, you have an air leak somewhere.
The common ones, in order of occurance, are as follows.
Between the carby and motor.
The crankshaft seal on the clutch side of the motor.
(clutch comes off with left hand thread)
The crankshaft seal under the flywheel, on the pull starter end.
I have had a spark plug leaking around it's gasket ring too, but that was a one of, and stumped everyone for a long time.
With the exception of the flywheel end, you can test with a can of starting fluid, spraying it into the areas mentioned until you get a change in behavior from the motor.
I the crank seals are gone, new seals will work for another period, but probably the bearings are getting loose and wearing the seals out.
Posted on Oct 17, 2009
Testimonial: "The air leak suggestion is a possibility; the gas tank cap idea I had tried already. I will advise on the air leak results when finished testing. "
bbreton
  • 437 Answers
SOURCE: My Homelite backpack leaf blower only idles. when
Is the new gas some you just mixed up from the gas station or is from the can in the garage? If it is indeed fresh then you are looking at needing the carburetor adjusted. Sorry you can not do it yourself, The epa only allows qualified technician to adjust them. Plus the tool to do so are not available to the general public.
HTH
Good Day.
Posted on Oct 31, 2009
Why does a leaf blower keep stalling after a period of use?
Ignition coil may be getting too toasty. Full throttle for 10 minutes.. yeah man no one does that. If factory calls for 50:1 gas/oil mix then richen it up to 40:1
Aug 21, 2013 | Poulan Garden
Ryobi blower stalls when not at full power
there is a gasket right under the prime plug most likely that is bad
Sep 20, 2012 | Ryobi Garden
Ryobi blower stalls
Not sure if your model has two throttles or one. It should have a trigger and a thumb lever. Be sure the thumb lever is closed. if that is not the problem your mixer might be to rich. it says 50:1, but use 40:1 and see if that helps
Jul 03, 2012 | Ryobi Blower Vac 205mph Leaf Blower Or...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Leaf blower that wont run at high rpm
You need to replace your fuel lines.
Nov 09, 2009 | Garden
Ryobi gas blower idles fine when i push the throttle it stalls
some carbs are not adjustable,check your air filter first to make sure its not rescricted and also a new plug,make sure your fuel is fresh,now if you do have adjusting screws,most have plastic caps on them with preset adjustments locked in,you will have to remove these caps to adjust,they need not be reinstalled,Hope this helps
Jun 09, 2009 | Ryobi Backpack Blower 25.4cc
Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
Your carburetor needs cleaned or you need a carb. kit depending on how old the carb. parts are. If you need tips on carb. cleaning, feel free to ask.
Jim
May 30, 2009 | Echo Garden
Husqvarna 125bvx Hand Held Blower Vac Logo
230 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
