Question about Samsung SyncMaster 191T 19" Flat Panel LCD Monitor
I GET NO CHECK SIGNAL CABLE ON MY SAMSUNG 913T, PLUG INTO MY SAMSUNG 932B AND IT WORKS FINE
  • 4234 Answers
SOURCE: CHECK SIGNAL CABLE
Typically this happens when the resolution of the display is out of range of the monitor. Normally this is when the resolution is too high. Have you changed the resolution settings? Also, not to be crass, but if there a video card in the system, be sure that you are connected to the correct VGA connector. With an extra card in the system, the onboard VGA connector is not used.
Keep us posted,
Dan
Posted on Jan 23, 2009
rubydu
  • 102 Answers
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
it shwos a compability issue with ur pc and monitor .somehow your sync signals are drop and not going to monitor at proper level...so u could replace your video data cable with new one.
or use a short length cable.it may solve your problem.
Posted on Jul 25, 2009
  • 64 Answers
SOURCE: My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Posted on Sep 22, 2009
  • 6 Answers
SOURCE: tried installing samsung syncmaster monitor and
If anothe monitor works fine plugged into the same slot, check the cord that goes from monitor to PC, on the monitor side, make sure it is seated firmly.
Posted on Oct 10, 2009
benwabnick
  • 2404 Answers
SOURCE: Samsung 932B Plus monitor does not turn on. Blinking LED
If you can open up the monitor from the back and get the cover off. Look on the power board and see if there are any puffy capacitors, most of the caps will have a silver flat top but if there are any bad ones, they will have a puffy top that stick up.
If you see any then make sure you replace them with capacitors of the same Uf rating and at least the same volts or more.
If you don't see any puffy caps then that means the screen is bad and the whole monitor would need to be replaced.
Posted on Nov 30, 2009
Testimonial: "Opened the LCD monitor up, and it was as he said. A bad capacitor. Thanks!! Replied within minutes."
LCD monitor Samsung 913T just turns off after awhile
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=SAMSUNG megnev2 =% 20 & 913v & Category = & kat2 = all
You may have to reset the EPROM, but take some voltage reading to make sure your power supply is OK and it does not have any badc caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 06, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
I rebooted my PC and now screen is darker and my colors are off
Check the contrast (darkness/lightness) on your Samsung LCD. There's a menu button on the monitor, press that and select contrast setting from the Menu.
Apr 29, 2010 | Samsung SyncMaster 932B LCD Monitor
I use my SyncMaster 932B display with my PC notebook. I un-plug and plug the monitor cable when I go on the road with my PC notebook. Today when I turn on the monitor I get the message "Check Signal Cable"
Several things to check,
1. make sure cable is securely connected on both end,
2. Make sure notebook is turned on
3. check to see if secondary monitor is disabled and enable it.
4. Depends on laptop you will have hot combination to toggle between screens usually is "Fn" + "F4"
Brand and model of notebook can be helpful
Dec 02, 2009 | Computers & Internet
Samsung monitor power light flashes long and short
Check the electrolytic capacitors with values 820uf/25V and 1000uf/10v. Replace them if found leaky..
Nov 21, 2009 | Samsung SyncMaster 932B LCD Monitor
Sep 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
When the monitor is turned on it displays "analog, digital" then "check signal cable", what is the problem?
check the data cable from the CPU to the monitor, it measn the monitor did not detect any signal from the CPu, or the system is not booting. Good luck
Sep 11, 2009 | Samsung SyncMaster 932B LCD Monitor
Samsung SyncMaster 191T 19" Flat Panel LCD Monitor Logo
113 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
